Autodesk Revit 2019 and Revit LT 2019
Autodesk Revit 2019 (trial)
[Image: 91727366711647283764.jpg]
[Image: 86505238963087155770.jpg]
[Image: 70796595813920443517.jpg]
[Image: 73137759560387907146.jpg]
[Image: 50896790689890709281.jpg]
[Image: 93016426356209147515.jpg]
[-] The following 19 users say Thank You to BennyP for this post:
  • rami1976, Filko, oanm2000, joker™, caifan, monter, PinkPant, temp1366, zrilek, Dell_Brett, kirankumarklk, araza023, febo927, chenamoy, mgdario, cristi, oyabun, avge, mariondon
If someone wants links for Revit LT 2019
  • oanm2000, joker™, PinkPant, Dell_Brett, rami1976
Autodesk® Structural Precast Extension for Revit® 2019
[Image: homepage.png]
[-] The following 11 users say Thank You to rami1976 for this post:
  • oanm2000, monter, febo927, rendel_©, caifan, cheosmith, ashcivilea, zrilek, Dell_Brett, joinsms, cristi
Other ADD on for revit :
Site Designer Extension
Infraworks to Revit Interoperability
FormIt Converter
Advance Steel Extension
[-] The following 13 users say Thank You to rami1976 for this post:
  • oanm2000, rendel_©, caifan, cheosmith, ashcivilea, zrilek, Dell_Brett, monter, Williams, The Engineer, highcivil, cristi, chicosi
Autodesk Revit 2019.1 Update:
No limits to creativity
[-] The following 10 users say Thank You to joker™ for this post:
  • anneb361, zrilek, PinkPant, rendel_©, oanm2000, monter, Dell_Brett, Plazski, Williams, cristi
Revit Extension for Fabrication 2019
  • joker™, oanm2000, cheosmith, zrilek, cristi
Advance Steel Extension for Revit 2019
[-] The following 7 users say Thank You to rami1976 for this post:
  • oanm2000, cheosmith, joker™, zrilek, Dell_Brett, monter, cristi
Autodesk Revit 2019.2 Update
[-] The following 4 users say Thank You to rami1976 for this post:
  • zrilek, oanm2000, Dell_Brett, monter
Autodesk 3DS Max 2019 trial rami1976 1 694 02-12-2019, 03:09 PM
Autodesk AutoCAD Architecture 2019 BennyP 2 1,043 02-01-2019, 12:28 AM
Autocad LT 2019 rami1976 3 1,063 02-01-2019, 12:20 AM
Autodesk AutoCAD MEP 2019 BennyP 1 789 12-13-2018, 10:38 AM
Autocad 2019 (x32 + x64) BennyP 6 4,292 09-21-2018, 02:57 PM
Last Post: joker™
