Autodesk Advance Concrete 2017
[Image: 31716636775104876990.gif]
[Image: 64573497277829419294.gif]
[Image: 01057255433612360836.gif]
[Image: 79463704790229609731.gif]
[Image: 73208256958175220293.gif]
Autodesk Advance Concrete is specifically designed for engineers and structural draftsmen looking for comprehensive and easy to use software.
With Advance Concrete, you can create a three dimensional model using powerful professional tools. Once the model is complete, you can automatically create all structural and reinforcement drawings using a large selection of view production tools, dimensions, symbols and automatic layout functions. Finally, you put your views in the layouts due to a manager and you can print or send them to a plotter and get high quality drawings.
Autodesk Advance Concrete is completely integrated in AutoCAD® making it easy and intuitive to learn. Autodesk Advance Concrete uses the latest AutoCAD® ObjectARX® technology. This advanced technology provides users with professional objects (e.g., beams, columns, and bars) perfectly integrated into AutoCAD® on which most standard functions (e.g., copy, paste, extend, trim, stretch, etc.) can be applied.
[-] The following 16 users say Thank You to BennyP for this post:
  • brandizzo, thanzawtun, rami1976, nexis35, TAFATNEB, PinkPant, Dell_Brett, zrilek, RajaK, promo8, Milkshake, Rodmo376, oanm2000, TurboXUser, bluefish80, fdgTG67
Autodesk Advanced Concrete 2017
[Image: 95359382326093449842.jpg]
Autodesk Inc., a world leader in 3D design software for entertainment, natural resources, manufacturing, engineering, construction, and civil infrastructure, announced the release of Advanced Concrete 2017 is specifically designed for engineers and structural draftsmen looking for comprehensive and easy to use software, including its own graphics engine allowing it to run with or without AutoCAD.
The application can be used for modeling and detailing different types of concrete structures, such as buildings, precast concrete elements, and also for civil engineering designs.
Advance Concrete uses AutoCAD technology.This technology provides users with professional objects (beams, columns, slabs, bars, frames, stirrup bars) integrated into AutoCAD and on which most basic AutoCAD functions can be applied (stretch, shorten, copy, move).
The main functions of Advance Concrete concern:
- 2D / 3D modeling of concrete structures;
- Automated drawings, with tools for automatic creation of sections, elevations, foundations, isometric views, etc.;
- Advanced reinforcement, with automatic creation and update functionalities and also with manual input tools;
- Creation of paper drawings;
- Automatic bill of materials.
- Multi-user modeling. Users can securely and simultaneously work on the same project through a shared database that stores the model data.
The program provides a working environment for creating 3D structural models from which drawings are created. The 3D model is created using Advance Concrete specific objects (structural elements, openings, rebars, etc.) and stored in a drawing (in DWG format). Once a model is complete, Advance Concrete creates all structural and reinforcement drawings using a large selection of tools for view creation, dimensions, interactive annotations, symbols, markings and automatic layout functions. Advance Concrete provides functionalities for automatic drawing updates based on model modifications.
[Image: comments.png]
[-] The following 9 users say Thank You to TAFATNEB for this post:
  • PinkPant, zrilek, promo8, oanm2000, monter, mgdario, bluefish80, Rihpi, caifan
Autodesk Advance Steel 2019 ML rami1976 1 1,146 04-13-2018, 02:51 PM
AutoDesk Advance Steel 2018 rami1976 1 2,491 04-07-2017, 05:55 AM
Autodesk Structural Bridge Design 2017 TAFATNEB 3 2,752 03-31-2017, 11:00 AM
Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 1,482 03-03-2017, 12:05 PM
Last Post: bus001
AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 1,284 03-01-2017, 02:35 PM
