AutoDesk Advance Steel 2018
Autodesk Advance Steel 2018 (64 bit )
[Image: 76618876166548353437.jpg]
Since acquiring Advance Steel in 2013, Autodesk continues to work towards better support for BIM-centric workflows for structural steel design and detailing.
With this new version ,that engineers can deliver more accurate designs and bills of materials to the detailer and fabricator. And for the detailer, it means they can more quickly respond to design changes while delivering the files needed to drive steel fabrication. This interoperability will help steel detailers and fabricators take full advantage of the steel design model—a notable benefit for the industry.
What’s more, the Autodesk’s Steel Connections for Revit 2018 release will include several major updates including over 130 parametric steel connections! These connections may be transferred to the Revit model to help improve design coordination between engineers and fabricators. The update will also have custom made framing Revit families for custom sections—a major feature that current users have been asking for—and the ability to transfer code check for customized parameters.
Advance Steel 2018 structural steel design toolset
Advance Steel detailing software gives structural engineers and detailers a large library of intelligent parametric structural elements, steel connections, and plates.
Main futures :
Parametric steel connections :Ready-to-use Connection Vault can help save time.
Built-in connection design engine Check steel-connection design in real time.
Stairs, railings, and cage ladders Model miscellaneous steelwork more quickly.
Sheet metal and folded plate work Create folded elements of any shape more quickly.
Create a call-out directly on drawing From a selected area in an existing drawing, create a call-out and assign it a specific scale.
Steel shop drawings Generate more accurate drawings for fabrication.
and more ...
AutoDesk Advance Steel 2018 Online Help
AutoDesk Advance Steel 2018 (X64) Languages Packs (English)
Moderator note:
Correct Thread name
[-] The following 18 users say Thank You to rami1976 for this post:
  • temp1366, oanm2000, giappichel, cace-01, Aburas, zrilek, cheosmith, Dell_Brett, malc, monter, dizz, macrem99, usman, Zacha01, TurboXUser, stldtlr, rendel_©, sructme
AutoDesk Advance Steel 2018 Object Enabler
[-] The following 7 users say Thank You to rami1976 for this post:
  • cheosmith, dizz, macrem99, oanm2000, Aviator, TurboXUser, rendel_©
Autodesk Advance Steel 2019 ML rami1976 1 1,206 04-13-2018, 02:51 PM
AutoDesk InfraWorks 360 Pro 2018 BennyP 1 1,852 03-10-2018, 12:15 PM
Autodesk Inventor 2018 BennyP 5 2,905 01-26-2018, 02:13 PM
Autodesk AutoCAD Plant 3D 2018 BennyP 1 2,064 12-18-2017, 10:32 PM
Autodesk Vehicle Tracking 2018 BennyP 2 2,441 12-18-2017, 10:27 PM
