Civil Engineering Association Software Software Product Autodesk Products Autodesk Structural Bridge Design 2017
10-10-2016, 08:33 AM
[Image: 37263832795006724953.jpg]
Autodesk Inc., a world leader in 3D design software for entertainment, natural resources, manufacturing, engineering, construction, and civil infrastructure, announced the release of Structural Bridge Design 2017. This software helps engineers achieve greater flexibility and efficiency in the design of small-to medium-span bridges integrating loading, analysis, and code checking processes whist providing an efficient workflow.
This single integrated software solution does not require valuable time importing, exporting or converting data instead it provides tools to help accelerate project completion.
Structural Bridge Design refines design options faster with automated updates in a define-analyse-code check loop whenever parameters change.
Engineers can additionally improve accuracy and reliability by reviewing code check requirements with detailed “hand” calculation-style design sheets that are created will full formulae and code referencing.
With Structural Bridge Design, users can deliver design reports faster using more accurate, reliable, consistent and verifiable data throughout the project lifecycle. These reports provide an understanding of engineering calculations involved to help maintain consistency and context throughout the project lifecycle.
To provide better understanding, the software creates side-by-side graphical displays of the data and results produced in the reports at all stages of analysis and design to offer further understanding of the results.
The design sections and bridge beams that are available within the software are based on a variety of international standards – including Eurocodes, AASHTO LRFD, British Standards as well Australian and New Zealand Standards. This allows users to create and develop their small-to-medium span bridges using required international standards before construction has commenced.
The functionality of Structural Bridge Design software can be simply broken down into three specific areas including:
- Section plan which deals with design on a section by section basis
- Girder design which works with the whole length of the girder
- Bridge Structure loading and analysis
Employing Autodesk Structural Bridge Design on your business’s projects will allow you to save time and money by utilising the tools available within the software.
[Image: comments.png]
  • PinkPant, blaze, oanm2000, temp1366, bridgeengineer, mgdario, Dell_Brett, cace-01, slowet, Rodmo376, bluefish80, piyush86, Hengki
 rami1976
User ID: 34597
Threads: 339
Likes: 9,517 in 1,136 posts
Given Likes: 1387
03-19-2017, 09:46 PM
Direct Link for trial version from autodesk
[-] The following 6 users Like rami1976's post:6 users Like rami1976's post
  • Dell_Brett, ali akbar, blaze, jfjdm, oanm2000, cace-01
 hmwere
Uganda
User ID: 17377
Threads: 132
Likes: 421 in 152 posts
Given Likes: 1475
03-31-2017, 09:42 AM
Request for only autodesk-2017-key-generator-x32 bit download link. (especially for this bridge software)
Thanks and regards
 BennyP
Valuable Former Deputy
User ID: 842
Threads: 1,128
Likes: 30,982 in 4,091 posts
Given Likes: 612
03-31-2017, 10:00 AM
The key generators for 2017 were posted here and the links are alive.
Now tell me, you ask without searching, you ask for another special key generator only for your bridge software or you simply post a useless post and try to receive a warning ?
  • hmwere, Aviator, oanm2000, cace-01
  Autodesk Structural Bridge Design 2024-32bit X86.ISO TAFATNEB 0 4,008 04-13-2023, 07:37 AM
  Autodesk Structural Bridge Design 2022 poolmand 0 3,873 11-01-2021, 08:06 AM
  Autodesk Structural Bridge Design 2018 (X32) BennyP 1 5,768 10-16-2017, 06:41 AM
  Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 4,749 03-03-2017, 11:05 AM
Last Post: bus001
  AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 5,941 03-01-2017, 01:35 PM
  Autodesk Revit 2017.1.1 TAFATNEB 0 4,909 12-19-2016, 07:26 AM
  Autodesk AutoCAD 2017.1.1 TAFATNEB 1 6,678 12-18-2016, 04:58 AM
