Civil Engineering Association eBooks Journals, Papers and Presentations Seismic retrofit of masonry buildings with polymer grid
Likes: 9,404 in 1,160 posts
Points:118,565 EP
04-03-2014, 12:50 PM
Author: A. Dusi & E. Manzoni Numeria Consulting Srl, Cremona, Italy. M. Mezzi Department of Civil and Environmental Engineering, University of Perugia, Perugia, Italy. G. Stevens Maccaferri NZ Ltd, Penrose, Auckland, New Zealand. | Size: 622 KB | Format: PDF | Quality: Unspecified | Publisher: roceedings of the Ninth Pacific Conference on Earthquake Engineering Building an Earthquake-Resilient Society 14-16 April, 2011, Auckland, New Zealand | Year: 2011 | pages: 8
[Image: 10844903203076185562.png]
The performance of masonry walls reinforced using innovative polymer grids embedded into thin plaster layers as a tools for the seismic enhancement of brick masonry buildings have been investigated by experimental tests. A number of diagonal compression, shear compression and out-of-plane tests were executed on sample panels; experimental activities included pseudo-dynamic and shaking table tests on infills and reduced scaled building mock-ups, respectively. The results of the experimental activities are presented and discussed. Experimental campaigns have been supported by theoretical and numerical investigations; based on the experimental data and on the results of detailed numerical simulations, simplified models to be used as tools for the design of the retrofitting intervention are hereinafter proposed. The models, calibrated on the experimental evidence, properly consider the collapse mechanisms as well as the grid
effect in the evolution of the above mentioned mechanisms.
  • PinkPant, ting tsai huang, vardan, ykhackhack, malc, draluka, caifan, blaze, civilgen, Grunf
  Seismic Retrofitting of Historic Masonry Buildings – Case Study Grunf 3 9,722 05-26-2016, 03:19 AM
Last Post: gulilero
  Constructing Seismic Resistant Masonry Houses in Indonesia RyanRS 0 3,804 07-19-2014, 04:44 AM
Last Post: RyanRS
  seismic retrofit of existing buildings : innovative alternatives TAFATNEB 0 3,782 05-09-2014, 11:08 AM
  Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp ar TAFATNEB 0 3,897 05-02-2014, 09:08 AM
  SEISMIC RETROFIT STUDY OF CABLE-STAYED BRIDGE ON TOKYO-GAIKAN EXPRESSWAY TAFATNEB 0 3,702 05-02-2014, 08:58 AM
  Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Co TAFATNEB 0 3,978 04-17-2014, 10:21 AM
  Performance-Based Seismic Retrofit Strategy for Existing Reinforced Concrete Frame Sy TAFATNEB 0 3,898 04-03-2014, 12:41 PM
