Seismic Behaviour and Retrofit of Historic Masonry Minaret
Current time: 01-21-2018, 11:30 PM
Author: TAFATNEB
Replies 0
Views 1078
Author: Prof. Ahmet Murat Turk, Ph.D. (Civ.Eng.) Istanbul Kultur University Civil Engineering Department.Cumhur Cosgun, B.Sc. (Civ.Eng.) Istanbul Kultur University Civil Engineering Department | Size: 0.73 MB | Format: PDF | Quality: Unspecified | Year: 2012 | pages: 07
[Image: 12363946681687409865.png]
The dynamic behaviour of block masonry minaret of a historical mosque in Istanbul is analyzed, and a seismic retrofit method is proposed. Due to high seismicity of the region, a 3D finite element model is used to determine lateral displacements and
failure modes under seismic load. The analyses show that the highest damage usually occurs at the base and the lower part of the minaret, and that lateral behaviour can be
improved by strengthening these sections with fiber reinforced polymer (FRP) sheets. The results obtained are promising in terms of seismic protection.
[-] The following 9 users say Thank You to TAFATNEB for this post:
  • rezart, Dell_Brett, gulilero, ykhackhack, vardan, malc, blaze, draluka, avge
Seismic Retrofitting of Historic Masonry Buildings – Case Study Grunf 3 3,245 05-26-2016, 04:19 AM
Last Post: gulilero
seismic retrofit of existing buildings : innovative alternatives TAFATNEB 0 996 05-09-2014, 12:08 PM
Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp ar TAFATNEB 0 830 05-02-2014, 10:08 AM
SEISMIC RETROFIT STUDY OF CABLE-STAYED BRIDGE ON TOKYO-GAIKAN EXPRESSWAY TAFATNEB 0 942 05-02-2014, 09:58 AM
Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Co TAFATNEB 0 1,095 04-17-2014, 11:21 AM
