Civil Engineering Association eBooks Journals, Papers and Presentations Effect of Lateral Load Patterns in Pushover Analysis
Likes: 9,403 in 1,160 posts
Given Likes: 2851
Points:118,565 EP
11-22-2013, 11:55 PM
Author: Abhilash R. Biju V. Rahul Leslie | Size: 0.25 MB | Format: PDF | Quality: Unspecified | Publisher: 0th National Conference on Technological Trends (NCTT09) 6-7 Nov 2009 College of Engineering Trivandrum 138 | Year: 2009 | pages: 5
Pushover analysis is a static, nonlinear procedure in
which the magnitude of the structural loading is incrementally
increased in accordance with a certain predefined pattern. With
the increase in the magnitude of the loading, weak links and
failure modes of the structure are found. Static pushover analysis is an attempt by the structural engineering profession to evaluate the real strength of the structure and it promises to be a useful and effective tool for performance based design. The performance point of the structure depends on the lateral load pattern applied,on the structure. Commonly applied load patterns are inverted triangle and uniformly distributed. Then guidelines like FEMA257 & 356 provide guidelines for lateral loads and doing pushover analysis. Here pushover analysis is done a typical RCC structure by applying different lateral load patterns using ETABS and SAP2000. The lateral load patterns used here are uniform load distribution and equivalent lateral force distribution as per FEMA-257, lateral loads from response spectrum analysis as per IS-1893(2002) and the lateral load pattern as per Upper-Bound Pushover analysis method.
  • malc, maad59, vardan, rezart, blaze, yanburak, learner20
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 4,316 10-21-2014, 08:57 AM
Last Post: Munykong
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 3,742 08-14-2014, 08:26 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 3,245 08-10-2014, 02:52 PM
  Pushover analysis of multi-st orey cantilever wall systems TAFATNEB 0 2,966 08-10-2014, 02:48 PM
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 3,357 08-10-2014, 02:42 PM
  Modal Pushover Analysis of SAC Buildings TAFATNEB 0 3,114 04-26-2014, 06:15 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 3,859 04-11-2014, 09:13 AM
