Control of Seismic Energy Partitioning of Bridge Piers with Sliding Rubber Bearing
Current time: 07-21-2018, 08:09 PM
Author: TAFATNEB
Replies 1
Views 1232
Author: Hirokazu Iemura1 , Yoshikazu Takahashi1 and Youzhen Chen1 1 Dept. of Civil Eng. Systems, Kyoto University, Kyoto, Japan | Size: 0.38 MB | Format: PDF | Quality: Unspecified | pages: 8
[Image: 56207577170695747208.png]
Base isolation bearings have many good properties for seismic protection of bridges. Recently a new sliding rubber bearing was developed, which has both characteristics of sliding and rubber bearings. When we install these seismic isolation systems, reasonable inelastic design method is required. But since the conventional inelastic design method takes into account only bridge piers, it is hard to design seismic isolators which can cope with the interaction between seismic isolators and bridge piers. The purpose of this study is to understand the relationship between the seismic isolation systems and piers with respect to their energy dissipation etc. and to attempt to propose a design procedure for isolated bridges.
[-] The following 3 users say Thank You to TAFATNEB for this post:
  • malc, cace-01, blaze
direct link
[-] The following 2 users say Thank You to andersen3 for this post:
  • vardan, gulilero
Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 1,498 12-26-2014, 10:49 PM
SEISMIC PERFORMANCE OF HIGH-STRENGTH-CONCRETE HOLLOW BRIDGE PIERS UNDER MULTI-DIRECTI TAFATNEB 0 1,011 06-03-2014, 09:39 PM
ANALYSIS ON SEISMIC PERFORMANCE OF ENERGY DISSIPATION SUBSIDIARY PIERS CONSIDERING FO TAFATNEB 0 1,056 05-02-2014, 10:27 AM
Seismic Retrofit of a Cable-S tayed Bridge with Passive Control Techniques: A Comp ar TAFATNEB 0 930 05-02-2014, 10:08 AM
Self-centering post-tensioned energy dissipating (PTED) steel frames for seismic regi arshiakh 1 1,519 07-21-2013, 12:27 AM
Last Post: Jackass
