Nonlinear seismic assessment of lightly reinforced concrete intake towers
Current time: 01-18-2018, 08:19 PM
Author: TAFATNEB
Replies 0
Views 997
Ensuring reservoir safety into the future. Thomas Telford, London, 2008 Nonlinear seismic assessment of lightly reinforced concrete intake towers
Author: R. SABATINO, Lloyd’s Register, London, UK (formerly KBR Ltd) A.J. CREWE, University of Bristol, UK W.E. DANIELL, University of Bristol, UK C.A. TAYLOR, University of Bristol, UK | Size: 1.8 MB | Format: PDF | Quality: Unspecified | Year: | pages: 14
[Image: 40269882173759137524.png]
Published guidance on the seismic analys is of reinforced concrete intake/outlet towers is limited, especiall
y for their nonlinear response, due to limited knowledge on the nonlinear characteristics ofexisting and new towers. Proving the integrity of existing towers is an international problem for dam owners, and an industrial need exists for arational, cost-effective and validated method for their assessment.This paper describes a series of tests aimed at investigating the seismic performance of typically reinforced, non-seismically designed towers.Monotonic and cyclic push-over tests were performed on 1/6th scaled models. The results from the physical tests were used to validate a 3D nonlinear finite element model of the towers, using embedded steel reinforcement and a smeared crack model to simulate crack properties of the concrete material. The dynamic performance of the structures was investigated by developing a simplified single degree of freedom model and performing a number of simulations to obtain fragility curves of the system. This simplified model was capable of simulating the degrading, hysteretic properties of the towers and was used to perform no nlinear time history analyses using a range of parameters. A probabilist ic approach was selected as the basis of the performance evaluation process using fragility analyses as a tool for modelling the uncertainty associated with the parameter selection. Based on the experimental and analytical results, a three-staged assessment procedure for the seismic performance assessment of the towers was proposed.
[-] The following 5 users say Thank You to TAFATNEB for this post:
  • rezart, malc, vardan, blaze, zrilek
Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 5,183 08-01-2017, 10:19 AM
Last Post: abdulazizk
Seismic evaluation of a 56-storey residential reinforced concrete high-rise building anfaga 3 1,647 02-10-2016, 03:49 PM
NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 1,628 11-15-2014, 03:07 PM
Seismic performance of concrete frame structures reinforced with superelastic shape TAFATNEB 0 1,346 09-05-2014, 02:59 PM
Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 834 08-10-2014, 03:59 PM
