Civil Engineering Association eBooks Journals, Papers and Presentations Seismic vulnerability assessment to slight damage based on experimental modal paramet
Likes: 9,403 in 1,160 posts
Given Likes: 2850
Points:118,565 EP
11-18-2013, 07:55 PM (This post was last modified: 11-18-2013, 07:59 PM by TAFATNEB.)
Seismic vulnerability assessment to slight damage based on experimental modal parameters
Author: Clotaire Michel , Philippe Gueguen , Matthieu Causse | Size: 1 MB | Format: PDF | Quality: Unspecified | pages: 50
The aim of this paper is to adjust behaviour models for each class of structure for vulnerability assessment by using ambient vibration. A simple model based on frequencies, mode shapes and damping, taken from ambient vibrations, allows computation of the response of the structures and comparison of inter-storey drifts with the limits found in the literature for the slight damage grade, considered here as the limit of elastic behaviour. Two complete methodologies for building fragility curves are proposed: (1) using a multi-degree of freedom system including higher modes and full seismic ground motion, (2) using a single-degree of freedom model considering the fundamental mode f0 of the structure and ground motion displacement response spectra SD(f0). These two methods were applied to the city of Grenoble, where 60 buildings were studied. Fragility curves for slight damage were derived for the various masonry and reinforced concrete classes of buildings.
A site-specific earthquake scenario, taking into account local site conditions, was considered, corresponding to an ML=5.5 earthquake at a distance of 15km. The results show the benefits of using experimental models to reduce variability of the slight damage fragility curve. Moreover, by introducing the experimental modal model of the buildings, it is possible to improve seismic risk assessment at an overall scale (the city) or a local scale (the building) for the first damage grade (slight damage). This level of damage, of great interest for moderate seismic prone
  • rezart, malc, vardan, blaze
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 9,763 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 3,240 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 4,221 07-19-2015, 07:24 AM
Last Post: Wolverine883
  SEISMIC VULNERABILITY ASSESSMENT USING AMBIENT VIBRATIONS: METHOD AND VALIDATION TAFATNEB 0 3,410 08-12-2014, 09:15 AM
  Specialist Meeting on the Seismic Probabilistic Safety Assessment of Nuclear Faciliti TAFATNEB 0 3,047 08-10-2014, 01:26 PM
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 3,465 08-10-2014, 01:15 PM
  SEISMIC ASSESSMENT OF AN IRREGULAR THREE-STOREY FULL SCA LE RC TEST STRUCTURE WITH SU TAFATNEB 0 3,213 06-03-2014, 09:11 PM
