Civil Engineering Association eBooks Journals, Papers and Presentations Size Effect on Shear Strength of Deep Beams: Investigating with Strut-and-Tie Model
 asim99
User ID: 9774
Threads: 476
Likes: 6,383 in 594 posts
Given Likes: 377
Points:54,091 EP
05-27-2013, 08:44 PM
Author: Tan, K. and Cheng, G. | Size: 583 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 2006 | pages: 13
Since a diagonally cracked deep beam behaves as a tied arch, the conventional plane section remaining plane approach is not
applicable to analyses of deep beams. Besides, for beams without web reinforcement, it has been shown that shear strength decreases as
member size increases. This is associated with a phenomenon called size effect. In this study, the causes of size effect on shear strength
of deep beams are investigated using both the strut-and-tie model STM and finite element model. The study shows that size effect in
concrete beam arises primarily from an inappropriate adoption of the shear transfer concept for steel beams. In addition, size effect also
depends on secondary factors such as the geometry of strut, and the spacing and diameter of web reinforcement. The modified STM is
verified with three published case studies comprising a total of 36 beams. Generally, the predictions are accurate and consistent, with a
uniform safety margin for different member sizes considered.
[-] The following 13 users Like asim99's post:13 users Like asim99's post
  • vardan, Jackass, Dell_Brett, viet2010, kowheng, Mohammad6299, malc, vvvv, ykhackhack, blaze, slowet, sodapas, zuhalz
  Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 4,036 03-16-2016, 09:41 AM
  Strut-and-Tie Model for Deep Beam Design odiclas 0 3,975 08-15-2014, 03:06 PM
Last Post: odiclas
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 3,283 06-01-2014, 03:35 PM
  MECHANICAL NONLINEAR SHEAR WALL MODEL TAFATNEB 0 3,434 05-30-2014, 01:20 PM
  Empirical Correlations: Drained Shear Strength for Slope Stability Analyses asim99 0 3,368 06-15-2013, 04:46 PM
Last Post: asim99
  Interactive Mechanical Model for Shear Strength of Deep Beams (With Discussion & Clos asim99 0 3,483 05-27-2013, 08:48 PM
Last Post: asim99
  Single-Span Deep Beams Subjected to Unsymmetrical Loads asim99 0 3,054 05-27-2013, 08:40 PM
Last Post: asim99
