The effects of long term uniform corrosion on the buckling of ground based steel tank
Current time: 09-19-2018, 11:33 AM
Author: arshiakh
Last Post: arshiakh
Replies 0
Views 1962
The effects of long term uniform corrosion on the buckling of ground based steel tanks under seismic loading
Author: Mahmoud R. Maheri; A. Abdollahi | Size: 3 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 2013 | pages: 9 | ISBN: --
Material degradation due to corrosion significantly alters the seismic response of ground-based cylindrical steel storage tanks. A numerical study is conducted to investigate the effects of internal shell corrosion on the dynamic buckling of three cone roof ground-based, steel cylindrical tanks with height to diameter ratios (H/D) of 0.40, 0.63 and 0.95, subjected to horizontal seismic base excitations. Internal corrosion is considered as a time dependent uniform thinning of the wall at the upper and the lower parts of the tank being in contact with, respectively, atmospheric oxygen and acid gases and residual water. Detailed numerical models of the tank–liquid systems at different stages of corrosion degradation are subjected to two representing accelerograms and for each model the critical peak ground acceleration (PGA) for dynamic buckling of the shell and its associated mode of failure are evaluated. It is found that in all three tanks, the critical PGA is markedly reduced with thinning of the shell, irrespective of the type of ground input. The buckling mode of failure of the tanks also changed from an elastic diamond-shaped failure at the top of the shell to an elasto-plastic elephant foot type failure near the base, after 10 years for the shorter tanks (H/D=0.4 and 0.63) and after 15 years for the tallest tank. The effects of uniform corrosion degradation on the critical buckling load of the tanks were found to be such that after 20 years of thinning due to corrosion, the static loading alone was responsible for the elephant foot buckling of the shell.
[-] The following 6 users say Thank You to arshiakh for this post:
  • kowheng, devilmaycry, PinkPant, malc, Dell_Brett, slowet
Long-term fatigue analysis of multi-planar tubular joints for jacket-type offshore wi TAFATNEB 1 1,753 06-19-2016, 01:48 AM
Last Post: englandboy
[ASCE] Buckling Analysis of a Long‐Span Roof Structure Collapsed during Construction mybest 1 2,119 04-08-2014, 12:35 PM
Last Post: Mohammad6299
Performance-based plastic design method for buckling-restrained braced frames arshiakh 1 1,757 11-28-2013, 12:58 PM
Optimizing groundwater long-term monitoring networks using Delaunay triangulation spa arshiakh 0 950 04-08-2013, 06:55 PM
Last Post: arshiakh
Hypothetical Earthquake Ground Shaking Estimation for Performance-Based Design benny 4 3,008 02-14-2013, 11:58 PM
Last Post: arshiakh
