Civil Engineering Association eBooks Journals, Papers and Presentations Assessment of the Environmental Effects on the Performance of FRP Repaired Steel Pipe
 asim99
User ID: 9774
Threads: 476
Likes: 6,383 in 594 posts
Given Likes: 377
Points:54,091 EP
05-21-2013, 07:42 PM
Assessment of the Environmental Effects on the Performance of FRP Repaired Steel Pipes Subjected to Internal Pressure
Author: Ramadan A. Esmaeel, Mohamed A. Khan and Farid Taheri | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: ASME | Year: 2011 | pages: 7
The use of composite materials for repair and rehabilitation of corroded steel pipes has
been increasingly growing in the oil and gas industry. However, there exists a noticeable
gap in the literature on the long term performance of composite repaired pipes, especially
those subjected to large internal pressure magnitudes. This work is an attempt toward
filing the gap by gaining a better understanding of the effects of environmental
conditions on the long term performance of composite repaired pipes subjected to large
internal pressures. Finite element method (FEM) is used to simulate typical composite
warp-repaired gouged steel pipes, conditioned in various environments and subsequently
subjected to internal pressure. The influence of the resulting degradation in composite’s
mechanical properties on the performance of the system was evaluated. To validate the
results, an experimental program was designed and carried out. Repaired specimens
were conditioned in an environmental chamber under certain thermal and moisture conditions;
then, the specimens were tested to failure subject to internal pressure. Good correlation
was obtained after fine tuning of FEM model’s material data through the use of
the experimentally obtained data.
[-] The following 5 users Like asim99's post:5 users Like asim99's post
  • Dell_Brett, Jackass, kowheng, ssobhan, malc
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 9,777 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 3,254 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 4,233 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Fire resistance assessment of steel structures mowafi3m 1 4,456 06-19-2015, 12:21 PM
Last Post: Dell_Brett
  The effects of aggregates characteristics on the performance of Portland cement ir_71 2 5,679 03-06-2015, 04:40 AM
Last Post: Veggeta
  Lateral-torsional buckling capacity assessment of web opening steel girders by artifi ssobhan 0 2,766 08-02-2014, 10:21 AM
Last Post: ssobhan
  EXPERIMENTAL MULTI-LEVEL SEISMIC PERFORMANCE ASSESSMENT OF 3D RC FRAME DESIGNED FOR D TAFATNEB 0 2,924 06-03-2014, 09:01 PM
