Civil Engineering Association eBooks Journals, Papers and Presentations Experimental and analytical study of the inelastic behavior of double angle bracing m
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
04-07-2013, 06:49 AM
Experimental and analytical study of the inelastic behavior of double angle bracing members under severe cyclic loading
Author: Aslani, Farhang; Goel, Subhash C. | Size: 33 MB | Format: PDF | Quality: Unspecified | Publisher: MCEER-NEES | Year: 1989 | pages: 423 | ISBN: -
[Image: 98361188900089267891.jpg]
Seventeen full-scale bracing members made of double angles in A36 steel with welded stitches and end gusset plates were tested under large cyclic deformations representative of severe earthquakes. Three types of section configuration, conventional back-to-back, strengthened back-to-back, and boxed section configuration, were investigated. Early fracture due to local buckling is the common mode of failure of conventional back-to-back angles. Strengthening of conventional back-to-back angles by welding two inclined plates does not improve member response due to unsymmetric buckling.
[-] The following 5 users Like arshiakh's post:5 users Like arshiakh's post
  • Dell_Brett, apocalipse, malc, kowheng, ssobhan
  Experimental studies of the ultimate behavior of seismically-isolated structures arshiakh 0 4,199 08-13-2014, 03:37 PM
Last Post: arshiakh
  Analytical Case Study of Seismic Performance of Retrofit Strategies for Reinforced Co TAFATNEB 0 4,146 04-17-2014, 10:21 AM
  Stitch Spacing and Local Buckling in Seismic‐Resistant Double‐Angle Braces asim99 0 3,507 04-03-2013, 04:46 PM
Last Post: asim99
  Cyclic Out‐of‐Plane Buckling of Double‐Angle Bracing asim99 0 3,642 04-03-2013, 04:44 PM
Last Post: asim99
  Theoretical and Experimental Study of Plate-Strengthened Concrete Columns under Eccen asim99 0 3,684 03-18-2013, 01:29 AM
Last Post: asim99
  Seismic Bracing of Non-Structural Elements asim99 0 3,319 02-03-2013, 09:39 PM
Last Post: asim99
  Experimental Verification of Viscous Damping Modeling for Inelastic Time History An. mybest 1 4,870 06-23-2012, 02:47 PM
Last Post: Grunf
