Civil Engineering Association eBooks Journals, Papers and Presentations Cyclic Out‐of‐Plane Buckling of Double‐Angle Bracing
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
04-03-2013, 04:44 PM
Author: Abolhassan Astaneh-Asl, Subhash C. Goel, and Robert D. Hanson | Size: 2.8 MB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1985 | pages: 19
The behavior of double-angle bracing members subjected to out-ofplane
buckling due to severe cyclic load reversals is investigated. Nine full-size
test specimens were subjected to severe inelastic axial deformations. Test specimens
were subjected to severe inelastic axial deformations. Test specimens were
made of back-to-back A36 steel angle sections connected to the end gusset plates
by fillet welds or high-strength bolts. Five of the test specimens were designed
according to current design procedures and code requirements. These specimens
experienced fracture in gusset plates and stitches during early cycles of
loading. Based on the observations and analysis of the behavior of these specimens,
new design procedures are proposed for improved ductility and energy
dissipation capacity of double-angle bracing members which buckle out of plane
of gusset plates. Tests of four specimens, designed using proposed procedures,
showed significant improvement in their performances.
[-] The following 5 users Like asim99's post:5 users Like asim99's post
  • jcbv, malc, kowheng, Dell_Brett, tluc
  Buckling of built-up compression members in the plane of the connectors asim99 2 6,748 12-12-2014, 04:39 PM
Last Post: Veggeta
  Capacity interaction in brick masonry under simultaneous in-plane and out-of-plane lo arshiakh 0 3,564 04-24-2013, 07:10 PM
Last Post: arshiakh
  Experimental and analytical study of the inelastic behavior of double angle bracing m arshiakh 0 3,284 04-07-2013, 06:49 AM
Last Post: arshiakh
  Stitch Spacing and Local Buckling in Seismic‐Resistant Double‐Angle Braces asim99 0 3,507 04-03-2013, 04:46 PM
Last Post: asim99
  Seismic Bracing of Non-Structural Elements asim99 0 3,319 02-03-2013, 09:39 PM
Last Post: asim99
  Global buckling analysis of plane and space thin-walled frames in the context of GBT yanburak 2 5,288 04-05-2012, 03:51 PM
Last Post: ssobhan
  DOUBLE ANGLE FRAMING CONNECTIONS SUBJECTED TO SHEAR AND TENSION Veggeta 0 3,698 11-25-2010, 06:36 PM
Last Post: Veggeta
