Civil Engineering Association eBooks Journals, Papers and Presentations Capacity interaction in brick masonry under simultaneous in-plane and out-of-plane lo
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
04-24-2013, 07:10 PM
Capacity interaction in brick masonry under simultaneous in-plane and out-of-plane loads
Author: M.A. Najafgholipour; Mahmoud R. Maheri; P.B. Lourenço | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 2013 | pages: 8 | ISBN: --
A considerable number of numerical and experimental studies, carried out to-date to investigate the behaviour of masonry walls under seismic loading, have considered the in-plane or the out-of-plane response of the wall separately without due consideration for any possible interaction between the two responses. In this paper, the results of a series of tests with different levels of simultaneous in-plane shear and out-of-plane bending actions on small brick walls are presented. The tests results indicate noticeable interaction between the in-plane shear and out-of-plane bending strengths of brick walls. Test results are also used to validate representing numerical models of wall panels. The combined in-plane/out-of-plane capacity interaction in full-scale walls having different aspect ratios is then investigated using these numerical models. It is found that the wall aspect ratio highly influences the interaction level, which must be considered in masonry design.
[-] The following 7 users Like arshiakh's post:7 users Like arshiakh's post
  • ziggywas1, kowheng, ykhackhack, devilmaycry, malc, Dell_Brett, slowet
  Buckling of built-up compression members in the plane of the connectors asim99 2 6,928 12-12-2014, 04:39 PM
Last Post: Veggeta
  Seismic Performance of Brick Infilled RC Frame Structures in Low and Medium rise Buil TAFATNEB 0 3,621 11-02-2013, 02:22 PM
  Cyclic Out‐of‐Plane Buckling of Double‐Angle Bracing asim99 0 3,750 04-03-2013, 04:44 PM
Last Post: asim99
  Dynamic Response Spectrum Analysis – Shear Plane Frame malc 2 6,255 07-21-2012, 09:38 AM
Last Post: shadabg
  Global buckling analysis of plane and space thin-walled frames in the context of GBT yanburak 2 5,425 04-05-2012, 03:51 PM
Last Post: ssobhan
  Geometric Propties of Plane Areas rezart 0 3,225 03-13-2011, 09:24 PM
Last Post: rezart
