Experimental Verification of Viscous Damping Modeling for Inelastic Time History An.
Experimental Verification of Viscous Damping Modeling for Inelastic Time History Analyzes
Author: Lorenza Petrini, Claudio Maggi, M. J. Nigel Priestley & G. Michele Calvi | Size: 2 MB | Format: PDF | Quality: Unspecified | Publisher: Taylor and Francis | Year: 2008 | pages: 22
Inelastic time history analyzes (ITHA) are recognized as the most suitable tool for describing the behavior of structures under seismic actions. It is clear that the reliability of ITHA results is strongly dependent on the modeling choices. One of the aspects still debated, in spite of a large amount of research, is the modeling of viscous damping forces. In the case of a single degree of freedom (SDOF) structure, the damping not represented by hysteretic response is commonly assumed proportional to the square root of the system stiffness: typically in the research papers it is not declared whether the initial or tangent-stiffness is considered. Recent research has shown that initial or tangent-stiffness proportional damping can give very different results in terms of energy dissipation, and peak response displacement. In this work, experimental and numerical tests performed to detect the most appropriate model are described and discussed.
[-] The following 10 users say Thank You to mybest for this post:
  • faros3000, kowheng, david-smith, malc, lisine, Grunf, zrilek, ting tsai huang, melkat, Dell_Brett
As an addition to the above posted article, I found one paper and one PowerPoint presentation wrote by the same, abovementioned, authors:
Effects of Damping Modelling on results of Time-History Analysis of RC Bridges
With regards,
[-] The following 8 users say Thank You to Grunf for this post:
  • zrilek, 3fan, faros3000, melkat, kowheng, malc, Dell_Brett, amir201
Assessment of Soil-Structure Interaction Modeling Strategies for Response History Ana TAFATNEB 0 1,159 05-09-2014, 05:13 PM
Non-linear time history analysis of tall structure for seismic load using damper TAFATNEB 0 1,142 04-17-2014, 10:48 AM
Experimental and analytical study of the inelastic behavior of double angle bracing m arshiakh 0 1,074 04-07-2013, 07:49 AM
Last Post: arshiakh
Midas Gen Advanced Webinar - Dynamic Analysis Time History melkat 0 1,278 11-27-2012, 04:16 PM
Last Post: melkat
Problem of the Use Viscous Damping in Structural Modelling Sumatra 3 2,480 06-23-2012, 12:23 PM
