Civil Engineering Association eBooks Journals, Papers and Presentations Design Rules of Built‐Up Members in Load and Resistance Factor Design
 asim99
User ID: 9774
Threads: 476
Likes: 6,383 in 594 posts
Given Likes: 377
Points:54,091 EP
04-03-2013, 04:22 PM (This post was last modified: 04-03-2013, 04:30 PM by asim99.)
Author: Lian Duan and Wai-Fah Chen | Size: 680 KB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1988 | pages: 11
The AISC-LRFD (American Institute of Steel Construction-Load and
Resistance Factor Design Specification for Structural Steel Buildings) Specification
provides rules for design of built-up members. The slenderness ratios of built-up
members that may buckle out-of-plane, say, about the Y-Y axis for a two-back-toback-
angle member are discussed. Based on the LRFD equation (E4-1) and the
usual concept of the effective length factor, a modification of the slenderness ratios
(Kl/r)m for built-up members as given in the present LRFD Specification is proposed.
The proposed formula with local effective length factor Km is concise, simple,
and physically clear. It is consistent with the effective length factor recommended
by the LRFD Specification, and has only one equation considering the
effects of shear and connectors on buckling of built-up members. The calculated
results of the proposed formula are found to be in good agreement with available
test results.
[-] The following 8 users Like asim99's post:8 users Like asim99's post
  • Dell_Brett, Quantumm, usman, jcbv, malc, kowheng, ykhackhack, bigone
  NIST: Best Practice Guidelines for Structural Fire Resistance Design of Concrete and ir_71 2 7,263 03-19-2017, 09:43 PM
Last Post: Dell_Brett
  Buckling of built-up compression members in the plane of the connectors asim99 2 6,471 12-12-2014, 04:39 PM
Last Post: Veggeta
  Design of Cold Formed Steel Unequel Angle Compression Members darkdkay 2 6,460 10-15-2014, 10:51 PM
Last Post: KhaLed-S.E
  Slenderness ratio of main members between interconnectors of built-up compression mem asim99 0 3,486 04-05-2013, 03:40 AM
Last Post: asim99
  Equivalent slenderness ratio for built-up members asim99 0 3,660 04-05-2013, 03:36 AM
Last Post: asim99
  An Alternate Method for Design of Reinf. Concr. Flex. Members odiclas 0 3,410 06-27-2011, 03:49 PM
Last Post: odiclas
  Stress Intensity Factor and Limit Load Handbook ir_71 0 3,525 05-30-2011, 05:47 AM
