Equivalent slenderness ratio for built-up members
Current time: 06-21-2018, 06:52 PM
Author: asim99
Last Post: asim99
Replies 0
Views 923
Author: MURRAYC . TEMPLEA ND GHADAE LMAHDY | Size: 270 KB | Format: PDF | Quality: Unspecified | Publisher: Canadian Journal of Civil Engineering | Year: 1992 | pages: 4
Built-up struts that buckle about an axis perpendicular to the plane of the connectors should be treated as a "built-up"
member as opposed to a "simple" member. This mode of buckling causes shear and moments in the connectors which
deform the connectors. These deformations increase the lateral deformation of the member and hence affect the load carrying
capacity. To account for this effect the easiest method is to use an equivalent slenderness ratio such as the
one included in the Canadian Standard. This note outlines the derivation of the equivalent slenderness ratio equation,
discusses when it should and should not be used, and includes a numerical example. A rewording of the applicable
clause in the Canadian Standard is suggested.
a- Follow the Forum Rules.
[-] The following 7 users say Thank You to asim99 for this post:
  • Dell_Brett, malc, ykhackhack, slowet, kowheng, tluc, Quantumm
Buckling of built-up compression members in the plane of the connectors asim99 2 1,919 12-12-2014, 05:39 PM
Last Post: Veggeta
Slenderness ratio of main members between interconnectors of built-up compression mem asim99 0 987 04-05-2013, 04:40 AM
Last Post: asim99
Design Rules of Built‐Up Members in Load and Resistance Factor Design asim99 0 1,012 04-03-2013, 05:22 PM
Last Post: asim99
