Slender thin cylindrical shells under unsymmetrical strip loads
Current time: 06-21-2018, 06:49 PM
Author: asim99
Last Post: asim99
Replies 0
Views 1018
Author: Adam J. Sadowski; J. Michael Rotter | Size: 2.4 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 2012 | pages: 11
Modern procedures for the design of shell structures against buckling have their basis in analytical studies of axisymmetric shell geometries under the very simple load cases of uniform compression, external pressure and torsion. Studies of more complex but realistic stress states were based on prebuckling analyses using either membrane theory or linear bending theory because even these involved considerable mathematical complexity. As a result, only limited conclusions for practical design could be drawn and the effects of geometric nonlinearity could not be assessed. With recent advances in computing power and nonlinear finite element programs, it is now possible to undertake nonlinear analyses of complex load patterns that would have been very difficult to do only a decade or so ago.
A number of practical load cases lead to a strip of pressure down one meridian, of which the best known ones are probably wind on tanks, eccentric discharge in silos, local thermal differentials, and partial fluid filling of a cylinder. This paper explores some of the rather unexpected stress patterns and modes of buckling that are predicted to develop in thin-walled cylindrical shells under such unsymmetrical strips of normal pressure. The results of a parametric study are presented to show the influence of the circumferential spread of the pressure strip on the structural behaviour. It is shown that the structural response to such loads may be very different, depending on whether the load acts inward or outward, and whether geometric nonlinearity and geometric imperfections are also included in the assessment.
a- Follow the Forum Rules.
[-] The following 5 users say Thank You to asim99 for this post:
  • Dell_Brett, slowet, kowheng, warbeast, malc
Single-Span Deep Beams Subjected to Unsymmetrical Loads asim99 0 1,180 05-27-2013, 09:40 PM
Last Post: asim99
Plastic Buckling of Cylindrical Shells: A Theoretical Analysis and Comparison with Te asim99 0 1,302 05-04-2013, 04:33 PM
Last Post: asim99
Plastic buckling of cylindrical shells under biaxial loading asim99 0 1,201 05-04-2013, 04:27 PM
Last Post: asim99
Plastic buckling of axially compressed circular cylindrical shells asim99 0 1,260 05-04-2013, 04:20 PM
Last Post: asim99
Dynamic elastic-plastic buckling of circular cylindrical shells under axial impact asim99 0 1,145 04-19-2013, 07:11 PM
Last Post: asim99
