Civil Engineering Association eBooks Journals, Papers and Presentations Investigation on Buckling Behavior of Cylindrical Liquid Storage Tanks Under Seismic
 mybest
Indonesia
User ID: 32155
Threads: 283
Likes: 3,957 in 566 posts
Given Likes: 686
03-29-2013, 12:19 PM
Investigation on Buckling Behavior of Cylindrical Liquid Storage Tanks Under Seismic Excitation: 2nd Report — Investigation on the Nonlinear Ovaling Vibration at the Upper Wall
Author: Hideyuki Morita, Tomohiro Ito, Koji Hamada, Akihisa Sugiyama, Yoji Kawamoto, Hideyasu Ogo and Eiji Shirai | Size: 1 MB | Format: PDF | Quality: Original preprint | Publisher: ASME | Year: 2003 | pages: 8
When a thin walled cylindrical liquid storage tank suffers a large seismic base excitation, buckling phenomena such as elephant foot bulge at the bottom portion and nonlinear ovaling vibration at the upper portion shows nonlinearity between the input and response level and suddenly occurs for the excessive input level, thus will be called as “nonlinear ovaling vibration” hereafter in this paper, may be caused. In the 1st report, the elephant foot bulge phenomena and the liquid pressure effects were investigated. In this 2nd report of the series of studies, the effect of nonlinear ovaling vibration phenomena were investigated based on the dynamic buckling tests using scaled models of thin walled cylindrical liquid storage tanks for nuclear power plants. The mechanism and the effect of vertical excitation and liquid sloshing were also studied and discussed.
[-] The following 12 users Like mybest's post:12 users Like mybest's post
  • Dell_Brett, kowheng, blaze, tluc, ssobhan, cace-01, jcbv, mahyarov, warbeast, malc, slowet, peixoto
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 6,037 03-01-2015, 08:09 PM
Last Post: bridgeengineer
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,046 10-08-2014, 02:06 PM
  SEISMIC BEHAVIOR OF DAMAGED BUILDINGS: A COMPARISON OF STATIC AND DYNAMIC NONLINEAR A TAFATNEB 0 4,078 08-10-2014, 02:06 PM
  Seismic Behavior of RC Elevated Water Tankunder Different Types of Staging Pattern TAFATNEB 0 4,222 05-10-2014, 08:16 AM
  FEM SEISMIC ANALYSIS OF STEEL TANKS FOR OIL STORAGE IN INDUSTRIAL FACILITIES TAFATNEB 0 4,045 05-10-2014, 07:52 AM
  Investigation of the behavior of the cable-stayed bridge under test load TAFATNEB 0 3,968 05-02-2014, 09:19 AM
  Behavior of high frequency modal responses in non linear seismic  analysis  TAFATNEB 0 4,344 04-17-2014, 09:57 AM
