Civil Engineering Association eBooks Journals, Papers and Presentations Alternate Path Method in Progressive Collapse Analysis
 rusty
Hungary
User ID: 17227
Threads: 68
Likes: 1,880 in 283 posts
Given Likes: 539
03-28-2013, 06:48 AM
Alternate Path Method in Progressive Collapse Analysis: Variation of Dynamic and Nonlinear Load Increase Factors
Author: McKay, A., Marchand, K., and Diaz, M. | Size: 1.64 MB | Format: PDF | Quality: Original preprint | Publisher: ASCE, Engineering Structures. Vol. 48. Issue 4. | Year: 2012 March | pages: 666-673
[Image: 32760401524526876819.png]
In performing alternative path analyses for checking the potential of a structure to progressive collapse, most designers often choose static procedures, which tend to be simpler and less labor demanding. As progressive collapse is a dynamic and nonlinear event, the load cases for the static procedures require the use of factors to account for inertial and nonlinear effects. A number of inconsistencies have been identified in the way the existing guidelines applied dynamic and nonlinear load factors to their static approaches. As part of an existing effort to update the existing guidelines, this study looked into the behavior of a variety of reinforced-concrete and steel moment-frame buildings to investigate the magnitude and variation of the dynamic and nonlinear load increase factors. The study concluded that the factors in the existing guidelines tend to yield overly conservative results, which often translate into expensive designs and retrofits. This study identified new load increase factors and proposes a new approach to utilize these factors when performing alternative path analyses for progressive collapse.
[-] The following 7 users Like rusty's post:7 users Like rusty's post
  • blaze, devilmaycry, slowet, ssobhan, kowheng, Dell_Brett, malc
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,577 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 4,934 05-09-2014, 02:00 PM
  Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 4,840 05-09-2014, 11:44 AM
  SIMULATION TECHNIQUES FOR COLLAPSE ANALYSIS OF RC BRIDGE UNDER STRONG EARTHQUAKE TAFATNEB 0 4,331 05-03-2014, 09:39 AM
  Progressive Collapse of Bridges—As pects of Analysis and Design TAFATNEB 0 4,362 05-02-2014, 09:02 AM
  Seismic collapse analysis on core-outrigger structures TAFATNEB 0 3,777 04-26-2014, 11:15 AM
  VULNERABILITY TO PROGRESSIVE COLLAPSE OF SEISMICALLY DESIGNED RC FRAMED STRUCTURES: C TAFATNEB 0 4,338 04-26-2014, 10:22 AM
