Civil Engineering Association eBooks Journals, Papers and Presentations Static Cone to Compute Static Settlement over Sand
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
Points:27,054 EP
02-23-2013, 10:25 AM
Author: JH Schmertmann | Size: 2.6 MB | Format: PDF | Quality: Scanner | Publisher: ASCE | Year: 1970 | pages: 36
by John H. Schmertmann, M.ASCE, (Prof. of Civ. Engrg., Univ. of Florida, Gainesville, FL)
Journal of the Soil Mechanics and Foundations Division, Vol. 96, No. 3, May/June 1970, pp. 1011-1043
Abstract:
At least two methods for using static cone data to predict settlement exist and have received extensive use—those of Terzaghi-Peck-Meyerhof and Buisman-DeBeer. Another method is presented in this paper. All three methods are then applied to 16 test cases involving either actual foundations, or plate load tests, with measured settlements. The proposed method simplifies calculations without sacrificing conservatism, yet appears most accurate over the full scope of the available test cases. These involve foundation widths of 2 ft to 184 ft. The key feature of the new method is that a single distribution of a strain influence factor is assumed for all cases. This method eliminates the need to compute the intermediate parameter of change in vertical stress with depth below a shallow footing. Also presented is a new correlation between static cone-bearing capacity and sand compressibility. Compressibility was measured in-situ by a special screw-plate form of plate-bearing load test. New data are included for the correlation between the static cone-bearing capacity and SPT blow count values in sands.
Improved Strain Influence Factor Diagrams
Author: JH Schmertmann | Size: 2.6 MB | Format: PDF | Quality: Scanner | Publisher: ASCE | Year: 1978 | pages: 36
by John H. Schmertmann, F.ASCE, Phillip R. Brown, M.ASCE, and John Paul Hartman, M.ASCE
Journal of the Geotechnical Engineering Division, Vol. 104, No. 8, August 1978, pp. 1131-1135
Abstract: Studies by the writers have added further insight to the Schmertmann strain factor method for the prediction of settlement over sand. The writers now make suggestions for several modifications to the method that should usually result in improved vertical strain distribution and settlement predictions under long footings.
[-] The following 8 users Like miquan's post:8 users Like miquan's post
  • Dell_Brett, blaze, joker™, kowheng, malc, tluc, A.Domingues, uetian19
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 4,384 08-10-2014, 02:42 PM
  SEISMIC BEHAVIOR OF DAMAGED BUILDINGS: A COMPARISON OF STATIC AND DYNAMIC NONLINEAR A TAFATNEB 0 3,777 08-10-2014, 02:06 PM
  Comparison between Static and Dynamic Analysis of Elevated Water Tank” TAFATNEB 0 4,710 05-10-2014, 09:18 AM
  Static pushover versus dynamic collapse analysis of RC buildings TAFATNEB 1 4,421 11-25-2013, 07:32 AM
  Nonlinear Static Analysis to Assess Seismic Performance and Vulnerability of Code - C TAFATNEB 0 3,990 09-03-2013, 07:28 AM
  Database of Friction Angles of Sand and Consolidation Characteristics of Sand, Silt, asim99 0 3,647 06-15-2013, 04:35 PM
Last Post: asim99
  Static Pushover Analysis Based on an Energy-Equivalent SDOF System asim99 1 4,548 04-01-2013, 04:07 PM
Last Post: ssobhan
