Simplified MCFT for Shear Capacity Scaling of R/C Beams
Current time: 09-19-2018, 06:36 AM
Author: lisine
Last Post: gulilero
Replies 1
Views 1189
A Simplified MCFT for Shear Capacity Scaling of R/C Beams
Author: M. T. Kazemi and V. Broujerdian | Publisher: Fracture of Nano and Engineering Materials and Structures, 42. | Size: 0.1 MB | Format: PDF | pages: 1363-1364 | Quality: Original Preprint | Year: July 3–7, 2006
[Image: 17771494928616946479.jpg]
Fracture of Nano and Engineering Materials and Structures Proceedings of the 16th European Conference of Fracture, Alexandroupolis, Greece
[-] The following 4 users say Thank You to lisine for this post:
  • kowheng, miquan, malc, mary
The content in the link of Post #1 is too short thus it appears to be the abstract of the paper.
I could not find the full paper but instead I found a related paper by the same authors.
Reinforced concrete beams without stirrups considering shear friction and fracture mechanics
Kazemi, M.T.1 ; Broujerdian, V.1
Source: Canadian Journal of Civil Engineering, v 33, n 2, p 161-168, February 2006; ISSN: 03151468; DOI: 10.1139/l05-100; Publisher: National Research Council of Canada
Author affiliation:
1 Department of Civil Engineering, Sharif University of Technology, P.O. Box 11365-9313, Tehran, Iran
Abstract:
A new expression for the shear capacity of reinforced concrete beams without stirrups was derived by calculating the aggregate interlock capacity across the major diagonal crack of the beam, a procedure somewhat similar to those based on the modified compression field theory. Two formulas were obtained from the simplification of this expression. All three relations capture the dependence of shear strength on the size of the beam, the ratio of shear span to beam depth, longitudinal reinforcement ratio, maximum aggregate size, and concrete strength. The limits of these formulas agree well with the limit solutions of shear failure load for very small and very large beams based on plastic and fracture mechanics solutions, respectively. The proposed relations were calibrated by least-squares fitting of the existing experimental database (consisting of 398 data points) and resulted in low coefficients of variation. The simplest version is suitable for design codes. © 2006 NRC Canada.(20 refs)
I also found another related paper by the same authors:
Smeared rotating crack model for reinforced concrete membrane elements
Broujerdian, Vahid; Kazemi, Mohammad Taghi
Source: ACI Structural Journal, v 108, n 3, p 379-380, May-June 2011; ISSN: 08893241; Publisher: American Concrete Institute
Yours truly, gulilero
[-] The following 4 users say Thank You to gulilero for this post:
  • malc, tomtumx, AlmostThere, nima_b12
Strength and Drift Capacity of GFRP- Reinforced Concrete Shear Walls TAFATNEB 0 1,069 03-16-2016, 10:41 AM
Interactive Mechanical Model for Shear Strength of Deep Beams (With Discussion & Clos asim99 0 1,590 05-27-2013, 09:48 PM
Last Post: asim99
Size Effect on Shear Strength of Deep Beams: Investigating with Strut-and-Tie Model asim99 0 1,587 05-27-2013, 09:44 PM
Last Post: asim99
A simplified approach for seismic calculation of a tall building braced by shear wall shadabg 0 1,475 08-02-2012, 06:05 AM
Last Post: shadabg
