Civil Engineering Association eBooks Structural Books Steel Joints in steel construction: Composite connections
 choonguan
User ID: 686
Threads: 16
Likes: 513 in 24 posts
Given Likes: 44
Points:2,177 EP
08-31-2009, 06:21 PM
This publication is one in a series of books (produced by the SCI/BCSA Connections Group) that cover a range of structural steelwork connections. It provides a guide to the design of composite connections in steelwork. Other books in the series are Joints in simple construction Vols 1 and 2 (to be replaced by Joints in steel construction: Simple connections), and Joints in steel construction: Moment connections. Included in the guide are composite end plate connections suitable for use in semi-continuous braced frames. Both beam to column and beam to beam details are considered, with full design procedures given. Guidance on frame design procedures is also given. Capacity tables are included for a range of standard details.
ISBN: 1859420850
Publisher: Steel Construction Institute
screenshots:
[Image: 1hviv2wsafl6ou4tdygq.jpg]
Download Links:
[-] The following 46 users Like choonguan's post:46 users Like choonguan's post
  • orambo, orambo, abudabeeja, abudabeeja, vvvv, vvvv, cnman, cnman, zrilek, zrilek, robertsas, robertsas, cristi, cristi, vish5610, vish5610, Grunf, Grunf, falconado, falconado, telefere, telefere, kardels, kardels, bubieng, bubieng, habermasian, stigtg, hcardenas, salahcivil, riprap, AG.NAYEL, RICARDI, dquan373, shdesign, pousin, toa011, adams, chenamoy, Dell_Brett, narendra, fer962933, jcbv, Nilupa, r3be1, bigone
 sheb101
User ID: 5471
Threads: 18
Likes: 447 in 35 posts
Given Likes: 163
Points:2,075 EP
10-24-2009, 10:13 PM
alternate version here:
Download Links:
[-] The following 30 users Like sheb101's post:30 users Like sheb101's post
  • Dell_Brett, Dell_Brett, kowheng, kowheng, jferrer, jferrer, baikur, baikur, Limpias72, zrilek, davegabj, simanta, geotecnico, nnn012, boycv, durden, Galileo, hans01, bangch, civilteam, dquan373, sameer0303, hernansgz, jcbv, ting tsai huang, Nilupa, tang1942, bigone, harsono, cabpcabp
 pousin
User ID: 7584
Threads: 5
Likes: 444 in 37 posts
Given Likes: 503
Points:1,197 EP
06-19-2010, 08:50 AM
THE SAME FILE BUT WITHOUT PROTECTION.
MIRROR LINK:
[-] The following 17 users Like pousin's post:17 users Like pousin's post
  • vardan, Dell_Brett, orambo, concreteok, zrilek, DamirDz, fathalla, thebeatles, fer962933, ssi3k, Jackass, Nilupa, slowet, Hengki, hignacio43, simanta, bigone
 vinnunsam
User ID: 3932
Threads: 36
Likes: 1,281 in 116 posts
Given Likes: 457
Points:9,083 EP
02-19-2014, 06:40 AM
SCI P213 Joints In Steel Construction - Composite Connection
Size: 4.59 MB | Format: PDF | Quality: Original preprint | Publisher: The Steel Construction Institute | Year: 1998 | pages: 102 | ISBN: 185942 085 0
[Image: 03972291041002766539.jpg]
This publication is one in a series of books that cover a range of structural steelwork connections. It provides a guide to the design of Composite Connections in Steelwork. Other books in the series are Joints in simple construction, Volumes 1 and 2 (shortly to be replaced by Joints in steel construction - Simple Connections), and Joints in steel construction - Moment Connections.
This guide includes composite end plate connections suitable for use in semi-continuous braced frames. Both beam-to-column and beam-to-beam details are considered. Guidance on frame design procedures is also given.
The publication begins with a list of ‘Fundamentals’. These points should be clearly understood by anyone wishing to design a frame incorporating composite connections.
This publication is produced by the SCVBCSA Connections Group, which was established in 1987 to bring together academics, consultants and steelwork contractors to work on the development of authoritative design guides for structural steelwork connections.
[-] The following 19 users Like vinnunsam's post:19 users Like vinnunsam's post
  • Mohammad6299, malc, blaze, PinkPant, vvvv, warbeast, jcbv, ting tsai huang, dinu69in, draluka, Andrew seah, Dell_Brett, bigone, Hengki, zrilek, harsono, xdesi, simanta, febo927
  Modelling Steel and Composite Structures TAFATNEB 0 2,502 04-25-2023, 10:57 AM
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 2,459 01-10-2023, 12:16 AM
Last Post: carolinandra
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,284 05-14-2020, 09:19 AM
Last Post: agelos100
  Australia Steel Ins Design example for multistorey composite steel framed building leong8929 2 2,783 01-18-2020, 05:45 PM
Last Post: monter
  Design of Joints in Steel and Composite Structures amindoxiti 3 2,873 12-17-2019, 06:53 AM
  Fatigue Design of Steel and Composite Structures: Eurocode 3: Design of Steel Structu asim99 3 2,991 04-30-2019, 01:29 PM
  Architecturally Exposed Structural Steel: Specifications, Connections, Details carolinandra 0 1,303 01-25-2019, 11:06 AM
