Journal of REINFORCED PLASTICS and COMPOSITES
Current time: 09-19-2018, 10:26 AM
Author: mybest
Last Post: mybest
Replies 0
Views 1009
January 2010
Size: 2.59 MB | Format: PDF | Publisher: SAGE | Year: 2010 | pages: Total 158
[Image: 56342417079386931558.gif]
The Journal of Reinforced Plastics and Composites publishes original research on a broad range of today's reinforced plastics and composites, including areas in: constituent materials, properties and performance, analysis and design, processing and fabrication, application. In addition, reports on special topics are regularly included such as recycling, environmental effects, novel materials, computer-aided design, predictive modelling, and "smart" composite materials.
Contents
1. Evaluation of the Physical and Mechanical Properties of Medium Density Fiberboard Made from Old Newsprint Fibers
2. Mechanical Performance of Short Banana/Sisal Hybrid Fiber Reinforced Polyester Composites
3. Characterization of Mechanical Behavior of Metallic and Non-metallic Particulate Filled Epoxy Matrix Composites
4. Studies on Bamboo/Glass Fiber Reinforced USP and VE Resin
5. Preparation and Physico-Chemical Study of Glass—Sisal (Treated—Untreated) Hybrid Composites of Bisphenol-C based Mixed Epoxy—Phenolic Resins
6. Comparison of Reinforcing Efficiency between Recycled Newspaper (RNP)/Carbon Black (CB) and Recycled Newspaper (RNP)/Silica Hybrid Filled Polypropylene (PP)/Natural Rubber (NR) Composites
7. Computational Modeling and Numerical Simulation of Flow-Induced Crystallization Kinetics During Injection Molding of Polyethylene Terephthalate
8.Effect of Knitting Tightness on Mechanical Properties of Weft-knit Glass Fiber Reinforced Epoxy Composites
9. Geometrical Correction to the Elastic Stiffness of Particulate Composites
10. Curing Characteristics and Mechanical Properties of Hybrid Palm Ash/Silica/Natural Rubber Composites
11. Fabrication Effects on Properties of Composites for Medical Applications: 1. Composite Preparation and Characterization
12. Effect of MAPE on Mechanical and Morphological Properties of Wheat Straw/HDPE Injection Molded Composites
13. Evaluation of Time Dependent Behavior of a Wood Flour/High Density Polyethylene Composite
14. Studies on Aluminum — Fly-Ash Composite Produced by Impeller Mixing
15. Surface Grafting of Polyethylene Fiber for Improved Adhesion to Acrylic Resin
Hello members, I upload this new material(I think, I've search and there is no).
If you think that this material is useful for us(Civil Engineer) then just press thanks button and I will continue to upload another content of this Journal but if you think not then Ignore Thanks button and I will look for another material for you.
Regards.
Riani aka mybest
[-] The following 6 users say Thank You to mybest for this post:
  • kowheng, Jackass, tluc, lisine, portal61, Grunf
Cement and Concrete Composites journal bridgeengineer 0 1,478 02-02-2015, 07:03 PM
Last Post: bridgeengineer
Journal of Composites for Construction - Papers lisine 1 1,486 01-14-2013, 11:25 AM
Self Compacting Hybrid Fiber Reinforced Concrete Composites for Bridge Columns kowheng 0 1,440 05-27-2012, 05:46 AM
