Civil Engineering Association eBooks Journals, Papers and Presentations A modal pushover analysis procedure to estimate seismic demands for unsymmetric-plan
 cve_jule
Macedonia
User ID: 6973
Threads: 32
Likes: 888 in 90 posts
Given Likes: 882
09-09-2011, 07:20 AM (This post was last modified: 09-09-2011, 11:17 AM by oanm2000.)
A modal pushover analysis procedure to estimate seismic demands for unsymmetric-plan buildings
Author: Anil K. Chopra and Rakesh K. Goel | Size: 576 KB | Format: PDF | Publisher: EARTHQUAKE ENGINEERING AND STRUCTURAL DYNAMICS | Year: 2004 | pages: 25
[Image: 40434869584616387983.jpg]
SUMMARY
Based on structural dynamics theory, the modal pushover analysis (MPA) procedure retains the conceptual simplicity of current procedures with invariant force distribution, now common in structural engineering practice. The MPA procedure for estimating seismic demands is extended to unsymmetric-plan buildings. In the MPA procedure, the seismic demand due to individual terms in the modal expansion of the effective earthquake forces is determined by non-linear static analysis using the inertia force distribution for each mode, which for unsymmetric buildings includes two lateral forces and torque at each floor level. These ‘modal’ demands due to the first few terms of the modal expansion are then combined by the CQC rule to obtain an estimate of the total seismic demand for inelastic systems. When applied to elastic systems, the MPA procedure is equivalent to standard response spectrum analysis (RSA). The MPA estimates of seismic demand for torsionally-stiff and torsionally-flexible unsymmetric systems are shown to be similarly accurate as they are for the symmetric building; however, the results deteriorate for a torsionally-similarly-stiff unsymmetric-plan system and the ground motion considered because (a) elastic modes are strongly coupled, and (b) roof displacement is underestimated by the CQC modal combination rule (which would also limit accuracy of RSA for linearly elastic systems).
KEY WORDS: modal pushover analysis; unsymmetric-plan building; seismic demands
[-] The following 20 users Like cve_jule's post:20 users Like cve_jule's post
  • kowheng, pedzaquino, Dell_Brett, pingfan2, zrilek, tluc, ruaumoko, oanm2000, sodapas, deadlord, Jackass, marion33, malc, gulilero, youceftli, mybest, SCREAM7890, cepot, rezart, TAFATNEB
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,054 10-08-2014, 02:06 PM
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 4,898 08-14-2014, 08:26 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,439 08-10-2014, 02:52 PM
  Pushover analysis of multi-st orey cantilever wall systems TAFATNEB 0 4,157 08-10-2014, 02:48 PM
  Comparison of Static and Dynamic Pushover Analysis in Assessment of the Target Displa TAFATNEB 0 4,694 08-10-2014, 02:42 PM
  Dynamic Analysis of Reinforced Concrete Building with Plan Irregularities TAFATNEB 0 4,590 05-30-2014, 01:43 PM
  Modal Pushover Analysis of SAC Buildings TAFATNEB 0 4,072 04-26-2014, 06:15 PM
