Civil Engineering Association eBooks Structural Books Steel DESIGN OF ALL-BOLTED EXTENDED DOUBLE ANGLE, SINGLE ANGLE, AND TEE SHEAR CONNECTIONS
Points:178,871 EP
04-25-2011, 05:13 AM
Author: PERRY GREEN, THOMAS SPUTO, ADAM HIGGINS | Size: 4.7 MB | Format: PDF | Publisher: AISC | Year: 2005 | pages: 430
[Image: 02878196682982371544.jpg]
This report presents a methodology for the design of all-bolted extended double angle, single angle, and tee shear connections. The report covers only the design of extended connections that involve beams and girders, but the principles set forth can be applied to connections to columns as well. Current steel connection design methodologies do not have standards for the design of extended connections which do not require that the beam be coped to allow clearance for the girder flange. Coping is an expensive and time consuming process which fabricators like to avoid if at all possible. Extended connections are a practical way to avoid coping. Using basic mechanics and code specific equations, a practical design for all-bolted extended shear connections can be derived. The derived methodology is used to formulate design tables that simplify the process. This report includes examples of how to use the design tables to design allbolted extended connections. The tables include design resistances for a wide range of angle and tee materials and bolts diameters, as well as different connection types.
[-] The following 48 users Like ir_71's post:48 users Like ir_71's post
  • kowheng, ascetic19, malc, darraccc, thebeatles, noelda2, knrsa, ting tsai huang, jaks, robertsas, pedzaquino, dbsimon29, rohailiyaz, blaze, seriousboy, vvvv, Grunf, henrycv, oanm2000, foxxx2010, eliseo.as, salahcivil, gatob, zrilek, jferrer, fran2009, sodapas, aidil01, Clouseau, baikur, fer962933, Draculina, hcardenas, techno, kmmh76, Jackass, subin91, Dell_Brett, kerenski_t, chenamoy, stash, cristi, carolinandra, Nilupa, saed, NAUTILUS87, warbeast, mowafi3m
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
Points:19,701 EP
12-12-2011, 02:46 AM
Made By CivilEA Post-Generator ver 2.1.2
[-] The following 2 users Like kvtasp's post:2 users Like kvtasp's post
  • Dell_Brett, NAUTILUS87
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,704 in 1,304 posts
Given Likes: 4610
Points:80,767 EP
10-25-2012, 11:40 AM
[-] The following 8 users Like lisine's post:8 users Like lisine's post
  • NAUTILUS87, Dell_Brett, eliseo.as, ting tsai huang, chenamoy, hignacio43, simanta, cabpcabp
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 2,459 01-10-2023, 12:16 AM
Last Post: carolinandra
  Design guide for concrete-filled double skin steel tubular structures carolinandra 0 1,142 04-16-2019, 04:02 PM
  Design and Analysis of Connections in Steel Structures: Fundamentals and Examples amindoxiti 1 2,097 12-16-2018, 07:54 AM
Last Post: malee
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,411 05-13-2016, 12:35 PM
Last Post: Dobblo
  Guide to Design Criteria for Bolted and Riveted Joints (2ed) Ultra Zone 4 3,367 12-16-2015, 05:42 PM
Last Post: cargadory2k
  Design Of Structural Connections To Eurocode 3 Frequently Asked Questions ir_71 2 3,169 05-13-2015, 07:09 AM
Last Post: Limpias72
  SCI P180: Integral Steel Bridges - Design of a Single-span Bridge - Worked Example ir_71 2 2,514 03-02-2013, 01:40 PM
Last Post: arshiakh
