Civil Engineering Association eBooks Structural Books Steel SCI P180: Integral Steel Bridges - Design of a Single-span Bridge - Worked Example
Points:178,871 EP
04-15-2011, 05:14 AM
Author: J A WAY, E YANDZIO | Size: 0.95 MB | Format: PDF | Publisher: SCI | Year: 1997 | pages: 91 | ISBN: 1859420567
[Image: 38317988078433938242.jpg]
This publication provides a Worked Example for the design of a single-span fully integral bridge, that utilises High Modulus Pile abutments and a composite plate girder deck. It has been based on the findings of studies undertaken on steel integral bridges and steel substructures by The Steel Construction Institute since 1993.
Calculations are provided for each design stage, together with a detailed commentary explaining the background to the methods employed and the parameters chosen. Computer-based numerical techniques have been used to enable full soil-structure interaction to be considered in the analysis. A design is proposed for a reinforced concrete capping beam to provide a full moment connection between the High Modulus Piles and the deck.
[-] The following 30 users Like ir_71's post:30 users Like ir_71's post
  • kowheng, melkat, blaze, Grunf, vvvv, LadaHitam, jcbv, narendra, seriousboy, almadar12, Dell_Brett, carolinandra, toa011, oanm2000, malc, miquan, sheb101, zrilek, subin91, cristi, Nilupa, sodapas, baikur, mecheil.edwar, kmmh76, tang1942, rigid_joint, warbeast, peixoto, bigone
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
11-16-2012, 09:53 AM
all links dead; mirror
password
[-] The following 12 users Like andersen3's post:12 users Like andersen3's post
  • Jackass, rusty, blaze, Dell_Brett, hignacio43, Quantumm, rigid_joint, KhaLed-S.E, davegabj, marion33, slowet, bigone
 arshiakh
User ID: 37777
Threads: 100
Likes: 3,224 in 617 posts
Given Likes: 214
Points:27,526 EP
03-02-2013, 01:40 PM
[-] The following 6 users Like arshiakh's post:6 users Like arshiakh's post
  • blaze, malc, peixoto, thesmileindark, bigone, Pinkto
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,411 05-13-2016, 12:35 PM
Last Post: Dobblo
  Steel Building Design: Worked examples for students rami1976 0 1,441 11-12-2015, 10:39 PM
  STEEL BRIDGES bigone 1 1,777 03-19-2015, 10:25 PM
Last Post: Veggeta
  Steel Bridges Fabrication mowafi3m 2 1,955 12-18-2013, 09:13 AM
  Steel Building Design: Worked Examples – Open Sections (SCI P364) jamildear4u 5 3,410 12-17-2013, 02:04 PM
  SCI P376 - Steel Building Design: Worked Examples for Students jamildear4u 3 1,853 10-13-2013, 08:38 AM
Last Post: vinnunsam
  Steel Truss 40 m Span - Solved Example mowafi3m 0 1,657 04-18-2013, 09:14 PM
Last Post: mowafi3m
