Civil Engineering Association eBooks Journals, Papers and Presentations Seismic response of a steel liquid storage tanks
 Apache
User ID: 261
Threads: 28
Likes: 575 in 49 posts
Given Likes: 199
03-27-2011, 03:45 PM
[Image: 22492800978455131327.jpg]
In this paper, the effectiveness of the base isolation on steel storage tanks has been investigated through
numerical models and then checked by shaking table tests on a reduced scale (1:14) model of a real
steel tank, typically used in petrochemical plants. In the experimental campaign the floating roof has also
been taken into account. The tests have been performed on the physical model both in fixed and isolated
base configurations; in particular two alternative base isolation systems have been used: high-damping
rubber bearings devices and sliding isolators with elasto-plastic dampers. Finally, a comparison between
experimental and numerical results has also been performed.
[-] The following 12 users Like Apache's post:12 users Like Apache's post
  • blaze, kowheng, 3fan, seriousboy, TAFATNEB, Dell_Brett, melkat, zrilek, Shahin, Umer.Aleem, erthqkengnr™, malc
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 5,808 12-26-2014, 09:49 PM
  Dynamic response of bare steel concrete under human rhythmic activities TAFATNEB 0 3,963 08-14-2014, 07:39 AM
  Seismic response of earth dams: some recent developments TAFATNEB 0 4,161 08-12-2014, 09:33 AM
  RESPONSE ANALYSIS STUDY OF A BASE-ISOLATED BUILDING BASED ON SEISMIC CODES WORLDWIDE TAFATNEB 0 4,951 08-10-2014, 01:15 PM
  FEM SEISMIC ANALYSIS OF STEEL TANKS FOR OIL STORAGE IN INDUSTRIAL FACILITIES TAFATNEB 0 4,044 05-10-2014, 07:52 AM
  RISK ASSESSMENT USING SEISMIC RISK MANAGEMENT AND RESPONSE ANALYSIS OF BASE ISOLATION TAFATNEB 0 4,336 12-20-2013, 09:05 AM
  Seismic response of steel frames containing hierarchical frictiondissipating joints TAFATNEB 1 4,817 11-28-2013, 12:08 PM
