Civil Engineering Association eBooks Journals, Papers and Presentations Guide to Improving the Effectiveness of Cement-Based Stabilization/Solidification
Points:178,871 EP
03-18-2011, 04:50 AM
Author: Jesse R. Conner | Size: 0.4 MB | Format: PDF | Publisher: PCA | Year: 1997 | pages: 55 | ISBN: 0893121762
[Image: 48442548447707253800.jpg]
Provides information on additives and field techniques that can improve the effectiveness of cement-based stabilization/solidification treatment of wastes. This 47-page guide includes discussions commonly occurring hazardous constituents in wastes and suggests additives and field techniques that can be used to successfully stabilize these constituents.
Portland cement-bases stabilization/solidification (S/S), has been used to successfully treat a wide variety of wastes. Some situations (because of the waste itself, the disposal scenario, and/or the regulatory requirements) require the use of additives or physical/chemical techniques to improve the effectiveness of cement-based S/S. The problems encountered in S/S can be broadly classified into solidification problems, i.e., adequately immobilizing the hazardous constituents of the waste. The Guide lists additives and techniques that can be applied to specific solidification problems such as problems in development of set, compressive strength, and free liquids. Also included are lists of additives and techniques that can be applied to immobilization of specific hazardous constituents such as lead, cadmium, and chromium, as well as classes of constituents such as volatile organics, organo-metallics and soluble salts. The Guide lists a variety of generic additives for specific desired stabilization/solidification effects, including those that can be used to control the pH of wastes; to reduce, oxidize, and co-precipitate constituents; and to accelerate or retard set. Contents 1. Introduction 2. Problems in Solidification and Physical Property Development - Setting Problems - Compressive Strength Development Problems - Permeability Development Problems - Durability Problems 3. Problems in Target Constituent Stabilization - Chemical Properties - Metals - Organics - Organo-Metallics - Soluble Salts 4. Additives Used in Cement-Based Solidification/Stabilization - Metal Stabilization - Immobilization of Organic Constituents -Processing and Anti-Inhibition Aids 5. Physical/Chemical Techniques Used in Cement-Based Solidification/Stabilization - Anti-Inhibition Aids - Physical Property Development - Processing Aids - Mixing Techniques
  • kowheng, usman, melkat, Grunf, blaze, cace-01, toa011, malc, oanm2000, isurya, cigutierrezg
  THE EFFECTIVENESS OF SEISMI C BUILDING CODE PROVISIONS ON REDUCING THE COLLAPSE RISK TAFATNEB 0 3,460 04-18-2014, 05:23 PM
  Effectiveness of modified pushover analysis procedure for the estimation of seismic d TAFATNEB 0 3,728 11-23-2013, 12:26 PM
  A high performance fibre reinforced cement based plaster for retrofitting RC members asim99 0 4,042 05-11-2013, 05:57 PM
Last Post: asim99
  Solidification and Stabilization of Wastes Using Portland Cement ir_71 0 3,056 03-17-2011, 06:39 PM
  Improving Portland Cement Concrete Mix Consistency and Production Rate through Two-St ir_71 0 4,412 11-20-2010, 06:11 AM
