Civil Engineering Association eBooks Structural Books Steel Eurobuild in Steel - Comparison of the Design of a Portal Frame
Points:178,871 EP
03-05-2011, 03:44 PM
Size: 4.41 MB | Format: PDF | Year: 2006 | pages: 98
[Image: 04423574194308643383.jpg]
The typical structure of a single-storey hall in most countries in Europe is the portal frame. This document provides a comparison of the calculation methods acc. to Eurocode 3 (EN 1993-1-1) and the national standard of the respective country. The calculation is performed for a typical portal frame structure in Europe. The frame uses hot rolled I-sections of steel grade S235 for the rafter and columns. Frame span is 30m and eaves height 5m, which are typical dimensions for small and medium sized industrial halls in Europe. Haunches are used for the eaves by providing additional hot-rolled sections welded onto the bottom flange of the rafter. The eaves connection as well as the apex is typically bolted and assumed rigid for this example, so that effects of rotations in the connections do not have to be taken into account. Column bases are pinned as no increased horizontal stiffness, e.g. for cranes, has to be provided.
[-] The following 32 users Like ir_71's post:32 users Like ir_71's post
  • kowheng, fashion, melkat, Dell_Brett, blaze, oreslaw, ssi3k, jcbv, Mohoh77, cordoba123, jferrer, giga, toa011, zainseiya, kg85arun, zrilek, robertsas, seriousboy, Grunf, manoj, monter, mastermind, Nilupa, baikur, kmmh76, slowet, vvvv, lisine, hmwere, ykhackhack, gulilero, cristi
 andersen3
User ID: 464
Threads: 54
Likes: 6,117 in 996 posts
Given Likes: 1243
Points:29,008 EP
11-22-2012, 05:50 AM
all links dead; mirror
password
[-] The following 21 users Like andersen3's post:21 users Like andersen3's post
  • warbeast, lednar_ved, stanislove, blaze, Dell_Brett, vvvv, subin91, Jackass, Trishu999, hmwere, malc, ykhackhack, gulilero, yanburak, stigtg, we_mbm, eng donny, cace-01, PinkPant, Pinkto, simanta
  Structural Fire Design to EC3 & EC4, comparison to BS5950 choonguan 2 2,329 05-10-2021, 03:44 PM
  Example in portal frame from A to Z mowafi3m 2 2,441 05-31-2018, 10:43 AM
Last Post: malee
  Steel Frame Design Examples febo927 1 1,516 05-28-2018, 01:57 PM
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,416 05-13-2016, 12:35 PM
Last Post: Dobblo
  Steel frame design - lecture bashir999 3 3,633 11-13-2014, 02:10 AM
Last Post: stlooi
  Advanced Analysis in Steel Frame Design - Guidelines for Direct Second-Order Inelasti asim99 1 1,821 07-07-2014, 03:08 AM
Last Post: i_kabir
  SCI P164: Design of Steel Portal Frames for Europe robertsas 3 3,776 02-17-2014, 08:42 AM
Last Post: vinnunsam
