Civil Engineering Association eBooks Structural Books Steel SCI P164: Design of Steel Portal Frames for Europe
 robertsas
Indonesia
User ID: 655
Threads: 159
Likes: 5,665 in 416 posts
Given Likes: 3149
Points:27,503 EP
01-18-2010, 02:03 AM (This post was last modified: 12-12-2011, 11:05 PM by usman.)
Design of Steel Portal Frames for Europe - SCI
The European Prestandard ENV 1993—1—1: Eurocode 3: Design of steel structures: Part 1.1
General rules and rules for buildings was published in 1992. The Steel Construction
Institute is in the process of preparing design guides to encourage the use of the Eurocodes
during their Prestandard or ENV periods. This publication will form part of a set of
design guides that will serve that purpose. It deals with steel portal framed buildings and
shows how to choose an efficient frame and prepare calculations to Eurocode 3.
The design principles presented in this publication are applicable for construction throughout
the European Economic Area (EU and EFFA), provided that the relevant National
Application Document of the country of use is complied with. The design guidance
includes additions to the Eurocode text derived from SC! P147 Plastic design of single
storey pitched roof portal frames to Eurocode 3, which was written as part of the Eureka
CIMsteel project.
Eurocode 3 may be more convenient than national standards in certain countries for the
design of steel portal frames. However, it is important that designers check that the key
requirements of the Eurocode on plastic design, Sections 5.2.1.4, 5.2.5 and 5.2.6.3, are
accepted in the National Application Document of the country where the structure is to be
erected. In some cases, the relevant national design standard may contain rules that are
compatible with this document instead. It is unlikely that Eurocode 3 will be used much
for the design of pitched roof portal frames to be constructed in the UK, because
BS 5950:1990 Structural use of steelwork in building: Part 1: Code of practice for design
in simple and continuous construction: ho: rolled sections gives greater economy in most
cases.
[Image: 13462353750916773003.jpg]
[-] The following 37 users Like robertsas's post:37 users Like robertsas's post
  • red_pool61, civilphongvan, rohailiyaz, lucky_b2me, Dell_Brett, Ultra Zone, oanm2000, chenamoy, zrilek, levanduy, boycv, Iktinos, subin91, baikur, bubieng, Thanhtung, cve_jule, Alexander, criogenox, whatahw, salahcivil, saif.mulla, qeddy, jcbv, strengr, Quantumm, Administrator , pm81, Nilupa, simanta, sharky, engrezi, blaze, duazo2009, andersen3, bigone, Mohammad6299
 mowafi3m
Egypt
User ID: 1236
Threads: 383
Likes: 9,293 in 668 posts
Given Likes: 1661
Points:54,968 EP
01-14-2011, 09:20 PM
Mirror
[-] The following 19 users Like mowafi3m's post:19 users Like mowafi3m's post
  • concreteok, usman, jferrer, robertsas, vardan, ssi3k, Dell_Brett, vvvv, oanm2000, cordoba123, zrilek, demertis, sodapas, Nilupa, jcbv, Svetoslav, TAFATNEB, bigone, Mohammad6299
 kvtasp
User ID: 7690
Threads: 69
Likes: 2,028 in 379 posts
Given Likes: 791
Points:19,701 EP
02-07-2012, 04:50 AM
[-] The following 14 users Like kvtasp's post:14 users Like kvtasp's post
  • kowheng, malc, kaci, slowet, Jackass, gulilero, jferrer, Dell_Brett, TAFATNEB, cristi, lednar_ved, bigone, Trishu999, Mohammad6299
 vinnunsam
User ID: 3932
Threads: 36
Likes: 1,281 in 116 posts
Given Likes: 457
Points:9,083 EP
02-17-2014, 08:42 AM
SCI P164 Portal Frame Design Guide Eurocode
Size: 1.80 MB | Format: PDF | Quality: Unspecified | Publisher: The Steel Construction Institute | Year: 2005 | pages: 203
[Image: 33267184679903073433.jpg]
The European Prestandard ENV 1993–1–1: Eurocode 3: Design of steel structures: Part 1.1 General rules and rules for buildings was published in 1992. The Steel Construction
Institute is in the process of preparing design guides to encourage the use of the Eurocodes during their Prestandard or ENV periods. This publication will form part of a set of design guides that will serve that purpose. It deals with steel portal framed buildings and shows how to choose an efficient frame and prepare calculations to Eurocode 3.
The design principles presented in this publication are applicable for construction throughout the European Economic Area (EU and EFTA), provided that the relevant National Application Document of the country of use is complied with. The design guidance includes additions to the Eurocode text derived from SCI P147 Plastic design of single storey pitched roof portal frames to Eurocode 3, which was written as part of the Eureka CIMsteel project.
Eurocode 3 may be more convenient than national standards in certain countries for the design of steel portal frames. However, it is important that designers check that the key
requirements of the Eurocode on plastic design, Sections 5.2.1.4, 5.2.5 and 5.2.6.3, are accepted in the National Application Document of the country where the structure is to be erected. In some cases, the relevant national design standard may contain rules that are compatible with this document instead. It is unlikely that Eurocode 3 will be used much for the design of pitched roof portal frames to be constructed in the UK, because BS 5950:1990 Structural use of steelwork in building: Part 1: Code of practice for design in simple and continuous construction: hot rolled sections gives greater economy in most cases.
This design guide was prepared by Mr C M King of The Steel Construction Institute with assistance from Mr M S Gough, Mr F J Naji and Mr M Adam Asamoah of The Steel Construction Institute.
[-] The following 22 users Like vinnunsam's post:22 users Like vinnunsam's post
  • Dell_Brett, blaze, vvvv, Mohammad6299, bigone, slowet, ikoleci, oanm2000, Andrew seah, vardan, toa011, malc, eliseo.as, seriousboy, warbeast, PinkPant, Hengki, Trishu999, zrilek, harsono, bridgeengineer, Aviator
  Plastic design of low-rise frames malc 0 1,156 10-06-2020, 03:46 AM
Last Post: malc
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,411 05-13-2016, 12:35 PM
Last Post: Dobblo
  SCI P101: Curtain wall connections to steel frames ir_71 3 3,093 02-27-2016, 04:51 AM
Last Post: cabpcabp
  Advanced Analysis of Steel Frames Theory, Software, and Applications abudabeeja 3 3,754 11-20-2014, 03:18 PM
  Moment Resistant Connections of Steel Frames in Seismic Areas: Design and Reliability Grunf 4 4,555 09-07-2014, 09:44 PM
Last Post: apocalipse
  Advanced Analysis and Design of Steel Frames Flexi 7 4,948 07-26-2014, 03:52 PM
Last Post: r3be1
  Stability Design of Steel Frames - W.F. Chen, E.M. Lui david-smith 4 3,430 03-09-2014, 03:45 AM
Last Post: subin91
