10-15-2010, 04:34 PM
Hollow Structural Section: Connections and Trusses - A Design Guide
![[Image: 02677140784365404938.jpg]](https://pic.civilea.com/images/02677140784365404938.jpg)
Second Edition (June 1997)
J.A. Packer and J.E. Henderson
In 1992, CISC introduced the world's first comprehensive SI Limit States Design guide for Hollow Structural Section (HSS) connections. Written by Dr. Jeff Packer, a world renowned HSS researcher, and Mr. Ted Henderson, an expert in fabrication, welding and erection of world class steel structures utilizing HSS members and connections, the 1992 Guide quickly became the reference for information on HSS connections for many -- world wide.
CISC is proud to introduce their latest, most comprehensive and up-to-date book on HSS, Hollow Structural Section Connections and Trusses - A Design Guide.
Based on CAN/CSA-S16.1-94, this 464-page Design Guide is a MUST for all designers, fabricators, detailers, architects, engineers, and others dealing with HSS construction.
All 13 chapters are expanded and updated to current specifications and in accordance with current international research information. Some of the new material contained in this Design Guide is as follows:
* Design tables listing the connection resistance for common T, gap K and overlap K connections for both circular and square HSS members.
* Multiplanar connections: XX, TX, TT, KK with circular HSS members.
* Blind bolting into HSS members.
* Power-nailed HSS member splices.
* New tighter minimum radii for bending HSS members.
* Complete update of weld resistances to S16.1-94; effective lengths of welds; Default vs. Simple vs. Precise weld sizing.
* More design examples: K connection concrete-filled vs. unfilled; XX connection; TX connection.
* More wide flange beam-to-HSS column connections and plate-to-HSS connections
![[Image: password.png]](http://forum.civilea.com/postgen/password.png)
