Civil Engineering Association eBooks Structural Books Steel DESIGN OF STRUCTURAL CONNECTIONS TO EUROCODE 3 FREQUENTLY ASKED QUESTIONS Watford, Se
Likes: 9,403 in 1,160 posts
Given Likes: 2855
Points:118,565 EP
08-31-2013, 12:53 PM
Author: Watford, September 2003 Building Research Establishment, Ltd. | Size: 10 MB | Format: PDF | Quality: Unspecified | Year: 2003
[Image: 85252299302274622552.png]
Developments in the design, fabrication and erection of steel structures together with
the introduction of new high performance materials have lead to significant changes in the design,
buildability and performance of steel structures and in particular their connections. Early steel
structures used riveted connections but following technological developments shop welded and site
bolted connections are now common place. The introduction of high strength steels has increased the
types and grades of bolt available to the designer. The range of bolts now includes ordinary strength
steels bolts such as grades 4.5, 4.6 and 5.6 and high strength steel bolts such as grades 8.8, 10.9 and
12.9. Developments in automatic fabrication have seen a move away from manually produced
drawings and setting out to sophisticated design software directly connected to numerically controlled
machines for laser cutting, punching and drilling. The quality of welding has also improved with the
introduction of continuous casting of steel and welding robots.
[-] The following 17 users Like TAFATNEB's post:17 users Like TAFATNEB's post
  • warbeast, slowet, gulilero, rezart, seriousboy, jcbv, malc, Dell_Brett, kowheng, eliseo.as, araza023, cristi, RyanRS, motivat, zrilek, levanduy, xdesi
  Cold-Formed Tubular Members and Connections. Structural Behaviour and Design TAFATNEB 0 2,367 04-25-2023, 10:48 AM
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 2,459 01-10-2023, 12:16 AM
Last Post: carolinandra
  Hollow structural section connections and trusses toa011 10 8,132 07-29-2022, 02:44 PM
Last Post: cace-01
  Architecturally Exposed Structural Steel: Specifications, Connections, Details carolinandra 0 1,303 01-25-2019, 11:06 AM
  Design and Analysis of Connections in Steel Structures: Fundamentals and Examples amindoxiti 1 2,097 12-16-2018, 07:54 AM
Last Post: malee
  Structural Steel Design to Eurocode 3 and AISC Specifications hich 1 2,168 05-31-2016, 06:08 PM
Last Post: ibg0203
  Design Of Structural Connections To Eurocode 3 Frequently Asked Questions ir_71 2 3,171 05-13-2015, 07:09 AM
Last Post: Limpias72
