Civil Engineering Association eBooks Journals, Papers and Presentations ASCE - Optimal Steel Fiber Strength for Reinforcement of Cementitious Materials
 datagap
User ID: 24267
Threads: 48
Likes: 695 in 68 posts
Given Likes: 176
01-23-2011, 06:06 PM (This post was last modified: 01-24-2011, 08:21 AM by datagap.)
Authors: Christopher K. Y. Leung and Nathan Shapiro,
ASCE Journal of Materials in Civil Engineering, Volume 11, pp. 116-123 (May 1999)
ISSN: 19435533 (online); 08991561 (print)
ABSTRACT
Steel fiber is the most common type of fiber reinforcement in cementitious materials. The reinforcement efficiency, in terms of maximum crack bridging force and total energy absorption during fiber pullout, is a function of many parameters including the properties of fiber, matrix, and interface as well as fiber size, volume fraction, geometry, and distribution. In this investigation, we focus on the effect of fiber yield strength on reinforcement efficiency. Fiber pullout specimens are fabricated with fibers of different yield strengths. Because cracks in a concrete member may intersect fibers at different angles, pullout tests are carried out with the fiber inclined at 0, 30, and 60°. The experimental results indicate the existence of an optimal fiber yield strength for the maximization of pullout load and pullout work. Inspection of the pullout curves as well as microscopic studies show that a higher fiber yield strength will result in more severe matrix spalling around the fiber exit point, thus limiting the further improvement in reinforcement efficiency. The results confirm the qualitative trend predicted by an existing theoretical model and indicate that the fiber yield strength is an important parameter that should not be overlooked in the design of fiber reinforced cementitious composites.
 psa_1987
Member
Banned
User ID: 2943
Threads: 24
Likes: 311 in 19 posts
Given Likes: 43
01-23-2011, 08:44 PM (This post was last modified: 01-23-2011, 08:47 PM by psa_1987.)
enjoy
[-] The following 10 users Like psa_1987's post:10 users Like psa_1987's post
  • datagap, Dell_Brett, malc, kowheng, usman, adshrt, nhim4mat2006, falloutboy, zainseiya, ticojuanjo
  Deterioration Mechanism of Cementitious Materials lisine 1 5,230 12-11-2016, 05:39 PM
Last Post: ronnie_150
  Strength of Embedded Steel Sections as Brackets - Alan H. Mattock and G. H. Gaafar pssst 1 4,778 10-23-2013, 02:29 PM
Last Post: deviationz
  Use Of Steel Fiber Reinforced Concrete In Structural Members With Highly Complex Stre aslam 1 4,932 04-08-2013, 08:00 AM
  ASCE - Creep Behavior and Its Prediction for Normal Strength Concrete Made from Crushed Clay Bricks as Coarse Aggregate melkat 0 3,802 05-22-2012, 02:49 PM
Last Post: melkat
  Guide for the use of stainless steel reinforcement in concrete structures ir_71 0 4,314 12-08-2010, 02:16 PM
  Punching shear strength of steel fiber high strength reinforced concrete slabs dler_amedi 0 4,580 11-24-2010, 10:45 PM
Last Post: dler_amedi
  Effects of Transverse Reinforcement and Bonded length on the Side-Blowout Capacity of Headed Reinforcement yucapareja 1 5,732 04-29-2010, 03:14 AM
Last Post: zbizafar
