Civil Engineering Association eBooks Journals, Papers and Presentations Strength of Embedded Steel Sections as Brackets - Alan H. Mattock and G. H. Gaafar
 pssst
Romania
User ID: 3083
Threads: 20
Likes: 574 in 54 posts
Given Likes: 401
Points:4,127 EP
10-28-2010, 12:57 PM (This post was last modified: 05-07-2012, 07:23 PM by mybest.)
Document Name: JL79-09
Author(s): Alan H. Mattock and G. H. Gaafar
Publication: Journal Proceedings
Volume: 79
Issue: 2
Pages: 83-93
Keywords: bearing capacity; brackets; columns (supports): compressive strength; construction; corbels; loads (forces); precast concrete; reinforced concrete; reinforcing steels; strength analysis.
Date: March 1, 1982
Abstract:
Reports an analytical and experimental study of the strength of steel sections embedded in a reinforced concrete column as brackets. The bearig stress at failure in the concrete below the embedded section is related to the concrete compressive strength and the ratio of the width of the embedded section to the width of the column. Expressions are developed for the vertical load carried by the embedded section and for the maximum moment in the embedded section when the concrete below the embedded sections fails in bearing. These expressions are shown to be in good agreement with the test results reported in the paper and with other test data in the literature. It is shown that the effective width of an embedded rolled steel l-section of normal proportions is equal to its flange width.
[-] The following 9 users Like pssst's post:9 users Like pssst's post
  • oanm2000, lasalleguy, Dell_Brett, jcbv, yanburak, michenerpark, yly8, Jackass, NBZ1400
 deviationz
User ID: 2031
Threads: 51
Likes: 546 in 107 posts
Given Likes: 72
Points:6,533 EP
10-23-2013, 02:29 PM
Can anyone post a new link to this paper?
  SCI P129: Building Design using Cold Formed Steel Sections: Fire Protection ir_71 2 5,803 12-18-2013, 08:42 AM
Last Post: bigone
  Column Tests of Cold-Formed Steel Non-Symmetric Lipped Angle Sections darkdkay 3 6,342 04-09-2013, 08:17 AM
  Optimized Sections for High-Strength Concrete Bridge Girders—Effect of Deck Concrete ir_71 1 5,080 03-02-2013, 05:08 AM
Last Post: arshiakh
  STRENGTH–DUCTILITY PERFORMANCE OF FLANGED BEAM SECTIONS CAST OF HIGH-STRENGTH CONCRET asim99 0 3,467 12-29-2012, 12:06 AM
Last Post: asim99
  ASCE - Optimal Steel Fiber Strength for Reinforcement of Cementitious Materials datagap 1 4,115 01-23-2011, 08:44 PM
Last Post: psa_1987
  An Analytical Model for Analysing Distortional Buckling of Cold-Formed Steel Sections darkdkay 1 3,648 01-08-2011, 05:37 PM
Last Post: Grunf
  Punching shear strength of steel fiber high strength reinforced concrete slabs dler_amedi 0 3,781 11-24-2010, 10:45 PM
Last Post: dler_amedi
