Civil Engineering Association Various Free Discussion good book about explanation of Young's modulus and stiffness
 george85
User ID: 27724
Threads: 40
Likes: 149 in 47 posts
Given Likes: 273
09-25-2010, 06:42 PM
Is there a good book which explains what is the Young's modulus - E and stiffness EA? I am also interested in derivation of the EA equation. From where did it became?
Also interested in all other types of modulus - Shear modulus? Any other?
09-25-2010, 08:18 PM
Concerning Modulus of Elasticity and Shear Modulus, try to find books called:
Otpornost materijala by Vice Šimić - there you should find lot of interesting things concerning materials and it is written in Croatian... As a student I was learning stuff from this book. (Lot of solved examples and good explained theory) Hope it helps.
With regards
G
p.s. for all non-English speakers - Otpornost materijala literary means Resistance of Material
and Šimić you can read as Shimich...
p.p.s. I'll try to find PDF format of the book but I can't promise you that - as soon as I find it, you'll have it.
[-] The following 1 user Likes Grunf's post:1 user Likes Grunf's post
  • george85
 daywalker
User ID: 11901
Threads: 13
Likes: 111 in 28 posts
Given Likes: 855
09-25-2010, 09:23 PM (This post was last modified: 09-25-2010, 10:31 PM by oanm2000.)
You should try this..
[-] The following 1 user Likes daywalker's post:1 user Likes daywalker's post
  • george85
 skyscraper
User ID: 15267
Threads: 5
Likes: 68 in 28 posts
Given Likes: 91
09-26-2010, 12:07 AM
I think "Semismic Design of Reinforced Concrete and Masonry Buildings" of T.Paulay and M.J.N. Priesttley is a text book to mention the structure stiffness in some chapters.
[-] The following 1 user Likes skyscraper's post:1 user Likes skyscraper's post
  • Grunf
 ASEC
Semi Senior Member
United States
User ID: 13344
Threads: 15
Likes: 397 in 113 posts
Given Likes: 297
09-26-2010, 03:32 AM (This post was last modified: 09-26-2010, 03:34 AM by ASEC.)
That basic stuff can be found in any reinforced concrete book and strength of material book. Download some in the books section and do some reading.
 george85
User ID: 27724
Threads: 40
Given Likes: 273
09-27-2010, 02:53 PM
Thank you for the answers, both of you. I didn't find the book you specified:
it seems that someone deleted it from the E-books folder.
But I found this one:
Reinforced Concrete Structures - Robert Park, Thomas Paulay
I do not know if this one is good or not?
 george85
User ID: 27724
Threads: 40
Given Likes: 273
10-01-2010, 05:21 PM
Ok I read some of the books you gave me.
At the end I realised that Young's modulus is a ratio of stress-strain diagram, but related only to the starting OA line (line where stress-strain relation is linear). Am I right?
Now I want to know what is the difference between stiffness and rigidity ?
 amautotech
User ID: 29709
Threads: 1
Likes: 2 in 1 posts
Given Likes: 5
10-01-2010, 06:05 PM
You may also consult "Strength of Materials" by Dr R.K.Bansal , published in India by "Laxmi Publications"
 jpver
User ID: 10
Threads: 9
Likes: 340 in 19 posts
Given Likes: 199
10-01-2010, 07:41 PM (This post was last modified: 10-01-2010, 08:58 PM by jpver.)
Hi george85
In general, stiffness and rigidity means the same thing. Both answers to the question how stiff or how rigid the material is when subject to load or deformation. In specific terms using numerical values, we normally use stiffness like what is the axial stiffness, flexural stiffness, torsional, or shear stiffness of the material rather than saying axial, flexural, torsional, or shear rigidity of the material. Sometimes, rigidity is referred to the toughness against volumetric deformation of the material.
Cheers
Jpver
[-] The following 2 users Like jpver's post:2 users Like jpver's post
  • george85, Grunf
 george85
User ID: 27724
Threads: 40
Given Likes: 273
10-02-2010, 05:50 PM
Thank you for the reply Jpver
What is the difference between Shear Modulus and Modulus of Elasticity Perpendicular (In application RFEM (program for structural analysis and design of constuctions) it is named by E90,meant
