ACI Structural Journal/July-August 2010
Current time: 11-14-2018, 07:10 PM
Author: Badis
Last Post: Badis
Replies 0
Views 2325
[Image: 13195966304770021724.jpg]
VOL. 107, NO. 04, JULY-AUGUEST 2010
107-s37 Performance of Retrofit Highway Barriers with Mechanical Anchors
107-s38 Nonlinear Analysis of Cross Sections under Axial Load and Biaxial Bending
107-s39 Analytical Modeling of Medium-Rise Reinforced Concrete Shear Walls
107-s40 Smeared Rotating Crack Model for Reinforced Concrete Membrane Elements
107-s41 Shear-Transfer Strength of Reinforced Concrete
107-s42 Seismic Design of Reinforced Concrete Bridge Columns at Subfreezing Temperatures
107-s43 Strengthening of Flat Slabs Against Punching Shear Using Post-Installed Shear Reinforcement
107-s44 Shear Behavior of Externally Prestressed Beams with Carbon Fiber-Reinforced Polymer Tendons
107-s45 Ultimate Strength of Reinforced Concrete Beams Retrofitted with Hybrid Bonded Fiber-Reinforced Polymer
107-s46 Transverse Resistance of Masonry Infills
107-s47 Punching Shear Behavior of Two-Way Slabs Reinforced with High-Strength Steel
107-s48 Compression Splices in Confined Concrete of 40 and 60 MPa (5800 and 8700 psi) Compressive Strengths
d107-s04 Five Discussions from the September/October 2009 ACI Structural Journal
[Image: 75883136686205779278.jpg]
[-] The following 13 users say Thank You to Badis for this post:
  • Dell_Brett, Grunf, kowheng, tarado, concreteok, cardinal85, oanm2000, yucapareja, juangpulidoc, fer962933, asiac, YeiYei, Umer.Aleem
Earthquake Spectra August 2010 Volume 26 Issue 3 igor1234 1 2,617 10-07-2014, 11:23 AM
Last Post: rossinando
Engineering Journal - First Quarter 2010 unix0123 1 2,102 08-17-2011, 03:46 AM
Last Post: joker™
Deep Foundation Institute (DFI) Journal - August 2010 OSHO 1 2,817 05-16-2011, 06:10 PM
Last Post: 3fan
Engineering Structures (July 2010) - Learning from Structural Failure Badis 1 2,823 03-12-2011, 06:07 PM
Last Post: Grunf
ACI Materials Journal SEPTEMBER-OCTOBER 2010 yanburak 2 2,747 10-08-2010, 05:40 AM
Last Post: concreteok
