Civil Engineering Association eBooks Codes, Manual & Handbook ACI MNL-17 - ACI Reinforced Concrete Design Handbooks (ACI SP 17)
 robertsas
Indonesia
User ID: 655
Threads: 159
Likes: 5,665 in 416 posts
Given Likes: 3149
03-22-2009, 12:23 AM (This post was last modified: 02-06-2024, 08:40 AM by Administrator.)
ACI DESIGN HANDBOOK
[Image: 45874060800759686658.jpg]
Design of Structural Reinforced Concrete Elements in Accordance with the Strength Design Method of AC1 318-95.
Design Examples On -
Base on ACI 99 with many example solved problem..
1. Flexure
2. Reinforcement
3. Shear
4. Footing
5. Deflection
6. Column
7. Two-way Slab
8. Seismic
PDF File ll 505 Pages
link contributed by vinnunsam
link contributed by Grunf
[-] The following 20 users Like robertsas's post:20 users Like robertsas's post
  • king12, king12, Dorogon, Dorogon, Ultra Zone, Ultra Zone, defeator, defeator, killoobilloo, killoobilloo, u4406014, ruaumoko, erimajus, super_engineer, sasan51, mumbaki, highcivil, techno, DamaD, bigone
 robertsas
Indonesia
User ID: 655
Threads: 159
Given Likes: 3149
03-23-2009, 04:27 AM
Title
Design Handbook: Beams, One-Way Slabs, Brackets, Footings, Pile Caps, Columns, Two-Way Slabs, and Seismic Design
American Concrete Institute
Publication Date:
Jan 1, 1997
Scope:
The ACI Design Handbook is intended for use by persons having a general familiarity with the strength design method and with “Building Code Requirements for Structural Concrete (ACI 3 18-95).”
This volume presents information for the engineering design and analysis of beams, slabs, brackets, footings, pile caps, columns, two-way slabs, and seismic design.
SECTIONS
Design Aids are tables and graphs intended to save the designer the effort of repeatedly performing routine calculations. All Design Aids apply to concrete having ƒ'a ranging between 3 and 12 ksi with Grade 40,60, and 75 steel reinforcement depending on the type of the structural member. A note at the bottom of each Design Aid indicates which Design Example illustrates the use of the table or graph.
Design Examples illustrate the use of the Design Aids (but are not intendeil to show how to design a structure).
Commentary on Design Aids gives the basis for the Design Aids. For judicious application and optimum efficiency, users of this handbook should first acquaint themselves with the Commentary. Design Examples will help verify procedures and results. It is not, however, the objective of the handbook to teach the novice how to design in reinforced concrete. Readers are expected to be competent in design before attempting to use this handbook.
(03-22-2009, 12:23 AM)robertsas Wrote: Base on ACI 99 with many example solved problem..
[-] The following 3 users Like robertsas's post:3 users Like robertsas's post
  • binh2907, super_engineer, bigone
 robertsas
Indonesia
User ID: 655
Threads: 159
Given Likes: 3149
02-12-2010, 01:06 AM
Try this link :
regards,
robertsasmita
[-] The following 27 users Like robertsas's post:27 users Like robertsas's post
  • Dell_Brett, amira, concreteok, lanz, u4406014, michaelsoe, prasat, kowheng, erimajus, super_engineer, sangen, sasan51, goober, baikur, boycv, rendel_©, salahcivil, mahfuzbangla, Pajipitar, a312, techno, stash, dbsimon29, sola4466, lisine, Hengki, bigone
 E123
User ID: 21746
Threads: 32
Likes: 605 in 39 posts
Given Likes: 8
06-13-2010, 07:52 PM (This post was last modified: 10-15-2012, 10:35 PM by usman.)
ACI SP-17(09) ACI Design Handbook
Design of Structural Reinforced Concrete Elements in Accordance with ACI 318-05
Size: 5.5 MB | Format: PDF | Quality: Unspecified | Publisher: American Concrete Institute | Year: 2009 | pages: 252 | ISBN: 9780870313417
[Image: 41956620603300155070.jpg]
Abstract: This publication provides information for the engineering design and analysis of beams, one-way slabs, footings, pile caps, columns, and seismic design in accordance with ACI 318-05. Information is presented in three sections: Explanatory Material, Design Examples, and Design Aids. The Introduction of each chapter includes explanatory material that provides the engineer with concise background of the subject. The Design Examples illustrate the use of the Design Aids, which are tables and graphs intended to eliminate routine and repetitious calculations.
Contents: Chapter 1—Design for flexure, p. 3
1.1—Introduction
1.2—Nominal and design flexural strengths (Mn and φMn)
1.3—Minimum flexural reinforcement
1.4—Placement of reinforcement in sections
1.5—Flexure examples
1.6—Flexure design aids
Chapter 2—Design for shear, p. 29
2.1—Introduction
2.2—Shear strength of beams
2.3—Designing shear reinforcement for beams
2.4—Shear strength of two-way slabs
2.5—Shear strength with torsion and flexure
2.6—Shear design examples
2.7—Shear design aids
Chapter 3—Short column design, p. 59
3.1—Introduction
3.2—Column sectional strength
3.3—Columns subjected to biaxial bending
3.4—Column examples
3.5—Column design aids
Chapter 4—Design of slender columns, p. 167
4.1—Introduction
4.2—Slenderness ratio
4.3—Lateral bracing and designation of frames as non-sway
4.4—Design of slender columns
4.5—Slender column examples
4.6—Slender column design aids
Chapter 5—Footing design, p. 189
5.1—Introduction
5.2—Foundation types
5.3—Allowable stress design and strength design
5.4—Structural design
5.5—Footings subject to eccentric loading
5.6—Footings examples
Chapter 6—Seismic design, p. 205
6.1—Introduction
6.2—Limitations on materials
6.3—Flexural members of special moment frames
6.4—Special moment frame members subjected to bending and axial load
6.5—Joints of special moment frames
6.6—Members of intermediate moment frames
6.7—Members not designed as part of the lateral-force-resisting system
6.8—Seismic design examples
6.9—Seismic design aids
Chapter 7—References, p. 229
7.1—Referenced standards and reports
7.2—Cited references
Appendix A—Reference tables, p. 231
Appendix B—Analysis tables, p. 237
Appendix C—Sectional properties, p. 251
[-] The following 86 users Like E123's post:86 users Like E123's post
  • vardan, batata666, robertsas, PSMUSACALA, kowheng, orambo, hatkam, concreteok, vantoancons, cardinal85, hernansgz, shuvo, nhim4mat2006, mahfuzbangla, pezhmankhan, vvvv, michaelsoe, toa011, super_engineer, Thanhtung, zbizafar, Grunf, killoobilloo, yphani222, StaadEng, Raktim, DamirDz, hassananas, hignacio43, shaqee, akbarkaz, wilsonseta, Civilized, ska51, surajdas, Galileo, osin, zego2000, mrco1124, engrszb, uetian19, DamaD, cristi, darkthrone, ali akbar, Yasir, malc, deadlord, jcbv, HASH007, theanhpe, ruaumoko, almadar12, blaze, parhyang, sodapas, Panjack39, hamzeaziz, ingchio, nuttapolk, oanm2000, davegabj, civilteam, thebeatles, rkce, isurya, aman0123445, sangen, salahcivil, jf28, gulilero, miquan, sivlad, Umer.Aleem, agelos100, simanta, ladjin, stash, erimajus, cesar3226, er.shyams, bigone, manzoor_quadri, ersin, sola4466, techno
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42472
06-13-2010, 08:35 PM
Contents of this post:
[Image: 95544925633044729322.jpg]
[Image: 72742621896768902612.jpg]
[-] The following 45 users Like Dell_Brett's post:45 users Like Dell_Brett's post
  • Grunf, yucapareja, robertsas, lednar_ved, concreteok, PSMUSACALA, orambo, vantoancons, maybc, nander, hernansgz, vardan, nhim4mat2006, mahfuzbangla, barbong, toa011, super_engineer, yantonegr, StaadEng, Raktim, golpesar, milano, surajdas, jason2180, civilteam, mrco1124, uetian19, DamaD, salvozesta2003, sodapas, Yasir, jcbv, HASH007, parhyang, Hengki, oanm2000, gacella, thebeatles, kristoffer_89, sivlad, er.shyams, manzoor_quadri, blaze, bigone, ibg0203
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Given Likes: 42472
06-14-2010, 07:22 AM
New Link:
[-] The following 57 users Like Dell_Brett's post:57 users Like Dell_Brett's post
  • Grunf, simanta, henrycv, jjmtz, Thanhtung, zbizafar, GROUT, killoobilloo, labofrock, civilteam, ngcanhtoan, sructme, StaadEng, Raktim, oanm2000, shaqee, rudyhera03, funmate69, surajdas, poite, osin, wysiwyg, mrco1124, a.fattouh, lcruzz, uetian19, civilphongvan, salvozesta2003, malc, chinh, einarmag, ssobhan, Yasir, HASH007, blaze, Hengki, mrjoesan2, Svetoslav, YeiYei, sivlad, ruaumoko, dbsimon29, er.shyams, highcivil, lisine, Alexander, knrsa, bigone, lasalleguy, salahcivil, ibg0203, melvinsantos, doguparthi, REYBARN, amirdana, sacem, harsono
12-29-2010, 09:19 AM
contents of the RAR file:
CHAPTER 1 - FLEXURE - SP-17 - 09-07
Chapter 2 - SHEAR DESIGN SP 17 - 09-07
Chapter 3 SP17 - 09-07
CHAPTER 4 - SLENDER COLUMNS - SP17 - 09-07
CHAPTER 5 - FOOTINGS - SP17 - 9-07
SEISMIC DESIGN - Chapter 6
Uploaded: Dec/29/2010, File Size: 4.9 MB, RAR'd 6 PDFs (paginated, search-able text)
[-] The following 28 users Like Grunf's post:28 users Like Grunf's post
  • almadar12, ssi3k, masafi_15, pedzaquino, shaqee, rudyhera03, subin91, parhyang, Dell_Brett, sodapas, Hengki, concreteok, usman, ravisbassi, oanm2000, mrjoesan2, redtony, jfjdm, we_mbm, Svetoslav, i_kabir, Jackass, sivlad, zainseiya, stash, zonoiko, er.shyams, bigone
 hilander
User ID: 21324
Threads: 13
Likes: 82 in 12 posts
Given Likes: 20
12-30-2010, 05:06 PM (This post was last modified: 12-31-2010, 12:51 AM by concreteok.)
There is an errata to this publication. I am not sure if it applies to this specific version. Anyway, you can download it there
mod: this is not link to the errata of the above document but aci search engine for their document errata.
[-] The following 11 users Like hilander's post:11 users Like hilander's post
  • Dell_Brett, zainalkaid, oanm2000, civilteam, mrjoesan2, Hengki, Yasir, Svetoslav, sivlad, stash, bigone
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
05-01-2012, 08:18 AM (This post was last modified: 05-01-2012, 10:46 AM by mybest.)
[-] The following 18 users Like miquan's post:18 users Like miquan's post
  • eng donny, Jackass, Dell_Brett, StaadEng, lisine, Alexander, blaze, rendel_©, marion33, jmromerot, eliseo.as, rafconsult, lednar_ved, chrono146, bigone, jackpotjoe, simanta, pram
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
08-22-2012, 07:00 AM (This post was last modified: 08-22-2012, 03:31 PM by BennyP.)
[-] The following 10 users Like david-smith's post:10 users Like david-smith's post
  • shadabg, ersin, malc, slowet, blaze, ruaumoko, techno, kowheng, salahcivil, bigone
Pages (3): 1 2 3 Next »
  [CivilEA Exclusive] ACI PRC-440.14-25: Design of Circular Concrete-Filled Fiber-Reinforced Polymer Tubes poolmand 0 2,094 08-17-2025, 10:25 AM
  ACI E702.5: Designing Concrete Structures: Slender Reinforced Concrete Wall Design - poolmand 0 1,371 08-28-2024, 05:32 AM
  ACI 343: Analysis and Design of Reinforced Concrete Bridge Structures noelda2 3 4,785 05-12-2024, 10:46 AM
  ACI SP-344: Examples for the Design of Reinforced and Prestressed Concrete Members Un poolmand 0 1,620 03-04-2024, 08:35 AM
  ACI SP-343: Fibre Reinforced Concrete: From Design to Structural Applications poolmand 0 1,683 03-04-2024, 07:50 AM
  ACI MNL-7: GFRP-Reinforced Concrete Design Handbook poolmand 0 1,978 01-08-2024, 05:05 AM
  ACI 343.1 Guide for the Analysis and Design of Reinforced and Prestressed Concrete Gu poolmand 0 1,800 11-26-2023, 11:51 AM
