Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive Seismic Design with Supplemental Energy Dissipation Devices
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
02-07-2010, 02:30 AM
by Robert D Hanson and TSU T Soong
The purpose of this monograph is to impart basic concepts of the supplemental energy dissipation technology to design engineers, architects, and buildings officials so they can understand its benefits and limitations in structural applications.
Authors: Robert D Hanson
University of Michigan, Ann Arbor, Michigan
TSU T Soong
State University of New York at Buffalo & Multidisciplinary Centre for Earthquake Engineering Research, Buffalo, New York
Contents
Message from EERI President
Message from NICEE
Foreward
Preface
Acknowledgments
Chapter 1: Introduction
Effect of Viscous Damping on Dynamic Response
Damper-Added Structure versus Traditional Structure
Design and Analysis
Chapter 2: Characterization and Applicability of Dampers
Metallic Yielding and Friction Devices
VE Solid Devices
Viscous Fluid Devices
Summary of Equivalent Damping and Stiffness
Applicability
Chapter 3: Analysis of Damper- Added Structures
Nonlinear Structure/Nonlinear Damper (NS/ND) Procedure
Nonlinear Structure/Linearized Damper (NS/LD) Procedure
Linear Structure/Nonlinear Damper (LS/ND) Procedure
Linear Structure/Linearized Damper (LS/LD) Procedure
Chapter 4: Damper Design for Structural Applications
General Considerations
Design Procedure
Design Examples
Application Examples
References
Appendix A: Nonproportional Damping Eigenvalue Solution
SDOF—Undamped System
SDOF—Viscous Damped System
MDOF—Undamped System
MDOF—Proportionally Damped System
MDOF—Nonproportionally Damped System
Appendix B: Code Development
Background
Appendix 13 for FEMA 368
[-] The following 1 user Likes aslam's post:1 user Likes aslam's post
  • jair523
  [REQUEST] Passive Energy Dissipation Systems for Structural Design and Retrofit david-smith 0 1,525 10-25-2012, 05:30 PM
Last Post: david-smith
  [REQUEST] Passive Energy Dissipation Systems in Structural Engineering sola4466 0 1,410 11-16-2011, 07:35 PM
Last Post: sola4466
  [REQUEST] Earthquake-resistant design based on energy concept renaldi 2 2,086 08-26-2011, 12:28 AM
Last Post: Badis
  [REQUEST] A unified analysis model for energy dissipation devices used in seismic structures chitbk 1 1,849 08-04-2011, 12:55 PM
Last Post: terrorruban
  [REQUEST] Seismic Design with Supplemental Energy Dissipation Devices by Robert D Hanson and TS aslam 0 1,498 07-28-2011, 05:01 AM
Last Post: aslam
  Design of Steel Triangular Plate Energy Absorbers for Seismic-Resistant Construction RICARDI 0 1,603 07-18-2010, 04:54 PM
Last Post: RICARDI
