Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Earthquake response of concrete gravity dams including hydrodynamic and foundation in
Away  preceptor
Senior Member
Banned
User ID: 8148
Threads: 119
Likes: 1,499 in 170 posts
Given Likes: 44
12-04-2009, 10:10 PM (This post was last modified: 04-05-2010, 07:04 PM by Grunf.)
Earthquake response of concrete gravity dams including hydrodynamic and foundation interaction effects
[Image: 96606349758169609398.jpg]
Chopra, Anil K.; Chakrabarti, Parthasarathi; Gupta, Sunil
UCB/EERC-80/01, Earthquake Engineering Research Center, University of California, Berkeley, 1980-01, 210 pages (540/C49/1980)
A general procedure is presented for the analysis of the response of concrete gravity dams, including the dynamic effects of impounded water and flexible foundation rock, to the transverse (horizontal) and vertical components of earthquake ground motion. The problem is reduced to one in two dimensions, considering the transverse vibration of a monolith of the dam. The system is analyzed under the assumption of linear behavior for the concrete, foundation rock, and water. The complete system is considered to comprise three substructures--the dam, represented as a finite element system; the fluid domain, as a continuum of infinite length in the upstream direction; and the foundation rock region, as a viscoelastic halfplane. The structural displacements of the dam are expressed as a linear combination of Ritz vectors, chosen as normal modes of an associated undamped dam-foundation system. The modal displacements due to earthquake motion are computed by synthesizing their complex frequency responses using fast Fourier transform procedures. The stress responses are calculated from the modal displacements. The response of idealized dam cross sections to harmonic horizontal or vertical ground motion is presented for a range of important system parameters characterizing the properties of the dam, foundation rock, and impounded water. Based on these results, the authors investigate and present conclusions concerning the separate effects of fluid-structure and foundation-structure interaction, and the combined effects of the two sources of interaction on the dynamic response of dams.
Edit reason: Dead link removed. (G)
[-] The following 14 users Like preceptor's post:14 users Like preceptor's post
  • kowheng, ziggywas1, zrilek, cmorpar, Dell_Brett, miquan, nhim4mat2006, mad_world, soringer, tuanpecc1, zainseiya, oanm2000, TAFATNEB, spat
04-05-2010, 07:25 PM
Mirror links:
[-] The following 12 users Like Grunf's post:12 users Like Grunf's post
  • user, jcoronellr, Ultra Zone, nhim4mat2006, avscorreia, oanm2000, pezhmankhan, adi04, sodapas, zainseiya, malc, zrilek
07-06-2011, 08:22 AM (This post was last modified: 12-24-2011, 10:07 AM by kowheng.)
PDF|RAR 7.09|6.37 MB
[-] The following 8 users Like kowheng's post:8 users Like kowheng's post
  • Dell_Brett, seriousboy, oanm2000, nhim4mat2006, Jackass, Gkatzogias, blaze, zrilek
 scorpion07
Albania
User ID: 550
Threads: 3
Likes: 1,366 in 104 posts
Given Likes: 277
12-15-2013, 11:18 AM
A 4shared link
[-] The following 14 users Like scorpion07's post:14 users Like scorpion07's post
  • vardan, warlord1, blaze, subin91, Dell_Brett, ssobhan, malc, mgdario, nhim4mat2006, draluka, zrilek, bridgeengineer, kowheng, sacem
05-10-2019, 12:52 AM
Size: 7.09 MB | Format: PDF
[-] The following 7 users Like kowheng's post:7 users Like kowheng's post
  • jcbv, PinkPant, pedzaquino, oanm2000, Dell_Brett, gulilero, ajmf77
  Fluid Viscous Dampers General Guidelines for Engineers Including a Brief History sabooryan 1 2,030 12-20-2022, 06:21 PM
Last Post: bridgeengineer
  Earthquake Engineering for Concrete Dams: Analysis, Design, and Evaluation Dobblo 0 1,535 04-09-2020, 05:49 AM
Last Post: Dobblo
  Guidelines on Design of Dams for Earthquake RyanRS 1 1,734 04-05-2015, 04:48 AM
Last Post: Veggeta
  Lecture Notes: Nonlinear Earthquake Response Analysis of Reinforced Concrete Building RyanRS 0 1,721 10-04-2014, 04:04 PM
Last Post: RyanRS
  Seismic Safety Evaluation of Concrete Dams: A Nonlinear Behavioral Approach cace-01 1 1,647 11-02-2013, 09:41 AM
Last Post: ssobhan
  Earthquake Response of Tall Regular Buildings - by Paul C Jennings smail 2 2,888 03-24-2013, 12:23 PM
Last Post: arshiakh
  Selecting and Scaling Earthquake Ground Motions for Performing Response-History Analy gulilero 0 1,650 11-08-2012, 01:04 AM
Last Post: gulilero
