Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive Stiffness Reduction Factor for Flat Slab
 bubieng
User ID: 3
Threads: 18
Likes: 42 in 9 posts
Given Likes: 300
12-03-2009, 04:00 PM
Stiffness Reduction Factor for Flat Slab Structures under Lateral Loads
Sang-Whan Han,1 Ph.D., P.E.; Young-Mi Park,2 and Seong-Hoon Kee3
1Professor, Dept. of Architectural Engineering, Hanyang Univ., Seoul 133-791, Korea. E-mail: [email protected]
2Graduate Student, Dept. of Architectural Engineering, Hanyang Univ., Seoul, Korea.
3Graduate Student, Dept. of Civil and Environmental Engineering, Univ. of Texas, Austin, TX 73301.
Effective beam width model (EBWM) has been widely used for predicting lateral drifts and slab moments in flat slab structures under lateral loads. As the slab moment due to lateral loads increases, slab stiffness decreases due to crack formation. The accuracy of the EBWM strongly depends on how the reduced slab stiffness is estimated. For this purpose, this study developed equations for calculating slab stiffness reduction factor () by conducting nonlinear regression analysis using stiffness reduction factors estimated from collected test results. The slab stiffness reduction factor () is defined as a ratio of reduced slab stiffness due to crack formation to the stiffness of the uncracked slab section. For verifying the proposed equation, the lateral stiffness of two slab–column connection specimens tested by the writers was compared with the lateral stiffness calculated using the EBWM with the proposed stiffness reduction factor. Further, two flat plate specimens having two continuous spans were also considered for verifying the proposed equations for .
  [REQUEST] Guide to Flat Slab Formwork and Falsework whwy99 1 1,980 07-18-2012, 05:30 PM
Last Post: Songoku
  [REQUEST] An Evaluation of the Prediction of Flat Slab Deflections gulilero 1 1,747 06-24-2012, 06:40 AM
Last Post: miquan
  [REQUEST] FLAT SLAB ANALYSIS AND DESIGN USING ETABS muthu.mj 5 4,911 03-17-2011, 12:10 AM
Last Post: kristoffer_89
  [REQUEST] Durrani, J. A. and AbouHashish, A. (1994). Earthquake Response of Flat Slab Buildings yly8 1 1,922 11-11-2010, 03:31 PM
Last Post: ssobhan
