Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] FLAT SLAB ANALYSIS AND DESIGN USING ETABS
[Request] FLAT SLAB ANALYSIS AND DESIGN USING ETABS
 muthu.mj
User ID: 28461
Threads: 9
Likes: 2 in 1 posts
Given Likes: 10
03-16-2011, 06:01 PM (This post was last modified: 03-16-2011, 06:42 PM by Dell_Brett.)
Dear friends,
Can someone tell me the procedure for designing flat slab using etabs or safe. I thank u all in advance for all your posts and replies.
Thanks & Regards,
Muthu
 zipatton
User ID: 1594
Threads: 4
Likes: 251 in 66 posts
Given Likes: 123
03-16-2011, 08:35 PM
Hi,
there is a very good (and quiet long) video in safe named "introduction to modelling" or something like that. It is very clear. Try it
Zippat
[-] The following 1 user Likes zipatton's post:1 user Likes zipatton's post
  • muthu.mj
 jehadsubuh
User ID: 1564
Threads: 2
Likes: 32 in 4 posts
Given Likes: 10
03-16-2011, 08:36 PM
(03-16-2011, 06:01 PM)muthu.mj Wrote: Dear friends,
Thanks & Regards,
Muthu
Etabs can't do the design of flat slabs, actually Safe is the entended program for these problems. you can go to the CSI website and download the video tutorials from this website or simply you can apply the examples of the quick tutorial of Safe
[-] The following 1 user Likes jehadsubuh's post:1 user Likes jehadsubuh's post
  • muthu.mj
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
03-16-2011, 08:53 PM
If you haven't done yet a two way flat slab/flat plate design I recommend that first you study the EFM (equivalent frame method) of ACI. Use a simple frame analysis software to do the calculation of static moments and the transversal distribution of the moments between column strips (CS) and middle strips (MS); I recommend using spSlab or ADAPT-RC. I believe the lastest SAFE has the EFM integrated but it does not do the transversal distribution of moments to the CS and MS. If your slab is regular you may use the Direct Method of ACI which uses prescribed coefficients to calculate CS & MS positive and negative moments.
I think you can do a preliminary design by first principles. Using a FEM is sometimes an overkill and it does not help novices to understand what the core of the design of slabs is. I am part of the old guard so I see lots of young engineers using sophisticated software but don't understand the basic principles.
g.
[-] The following 6 users Like gulilero's post:6 users Like gulilero's post
  • kristoffer_89, muthu.mj, Dell_Brett, jcoronellr, mahfuzbangla, KevinCNair
 techno
User ID: 4555
Threads: 95
Likes: 244 in 127 posts
Given Likes: 2286
03-16-2011, 10:37 PM
ETABS can't design slab, it just gives the analysis result.
However, you can use the analysed result to design using a 3rd party software.
Normally, i will design the floor with PROKON.
Well, it's good if you wan to export the floor to SAFE and let it to design for you.
But, what i suggested is try to design using a 3rd party software from ETABS result. You will learn more about the FEM result.
[-] The following 2 users Like techno's post:2 users Like techno's post
 kristoffer_89
Philippine
User ID: 6774
Threads: 14
Likes: 379 in 49 posts
Given Likes: 514
03-17-2011, 12:10 AM
@techno
Can you please kindly give us a simple procedure to carry out the design of slab from etabs anlaysis? I am already thinking of this, but I am a bit confused, as forces (M11,M22) yield large amounts of moment near areas of stress concentration.
Can we take the average moment across a design strip?
[-] The following 1 user Likes kristoffer_89's post:1 user Likes kristoffer_89's post
  • Batman07
  [REQUEST] Guide to Flat Slab Formwork and Falsework whwy99 1 1,977 07-18-2012, 05:30 PM
Last Post: Songoku
  [REQUEST] Guide to the Design & Construction of Reinforced Concrete Flat Slabs Songoku 2 2,713 07-04-2012, 08:55 PM
Last Post: gulilero
  [REQUEST] An Evaluation of the Prediction of Flat Slab Deflections gulilero 1 1,739 06-24-2012, 06:40 AM
Last Post: miquan
  [REQUEST] Effective Beam Width Coefficients for Equivalent Frame Analysis of Flat-Plate Structu yly8 0 1,585 12-14-2010, 12:33 AM
Last Post: yly8
  [REQUEST] Durrani, J. A. and AbouHashish, A. (1994). Earthquake Response of Flat Slab Buildings yly8 1 1,917 11-11-2010, 03:31 PM
Last Post: ssobhan
  Stiffness Reduction Factor for Flat Slab bubieng 0 1,720 12-03-2009, 04:00 PM
Last Post: bubieng
