Civil Engineering Association eBooks Codes, Manual & Handbook AASHTO AASHTO T307: Standard Method of Test for Determining the Resilient Modul
01-04-2022, 11:19 AM (This post was last modified: 01-25-2022, 11:23 AM by Administrator.)
AASHTO T 307-99 (12)(21): Standard Method of Test for Determining the Resilient Modulus of Soils and Aggregate Materials
| Size: 1.1 MB| Format: PDF| Quality: Original preprint| Publisher: AASHTO| Year: 1 January 1999 (reapproved 2012, 2021)| pages: 41
This method covers procedures for preparing and testing untreated subgrade soils and untreated base/subbase materials for determination of resilient modulus (Mr) under conditions representing a simulation of the physical conditions and stress states of materials beneath flexible pavements subjected to moving wheel loads.
The methods described are applicable to undisturbed samples of natural and compacted subgrade soils, and to disturbed samples of subgrade soils and untreated base/subbase prepared for testing by compaction in the laboratory.
In this method, stress levels used for testing specimens for resilient modulus are based on the location of the specimen within the pavement structure. Samples located within the base and subbase are subjected to different stress levels as compared to those specimens that are from the subgrade. Generally, specimen size for testing depends on the type of material based on the gradation and the plastic limit of the material as described in a later section.
The value of resilient modulus determined from this procedure is a measure of the elastic modulus of untreated base and subbase materials and subgrade soils recognizing certain nonlinear characteristics. . Resilient modulus values can be used with structural response analysis models to calculate the pavement structural response to wheel loads, and with pavement design procedures to design pavement structures.
This standard may involve hazardous materials, operations, and equipment. This standard does not purport to address all of the safety concerns associated with its use. It is the responsibility of the user of this standard to consult and establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
  • babakfeyzi, cace-01, kowheng, zrilek, Dell_Brett, PinkPant
  AASHTO M259: Standard Specification for Precast Reinforced Concrete Monolithic Box Se poolmand 1 3,239 09-23-2024, 10:15 AM
  AASHTO R69: Standard Practice for Determination of Long-Term Strength for Geosyntheti poolmand 0 2,890 01-15-2024, 09:01 AM
  AASHTO M351: Standard Specification for Cotton Duck Fabric Bridge Bearings, poolmand 0 2,881 01-15-2024, 08:42 AM
  AASHTO M270M/M270: Standard Specification for Structural Steel for Bridges poolmand 0 2,777 01-15-2024, 08:34 AM
  AASHTO M207M/M207: Standard Specification for Reinforced Concrete Elliptical Culver poolmand 0 2,670 01-08-2024, 05:25 AM
  AASHTO T85: Standard Method of Test for Specific Gravity and Absorption of Coarse poolmand 0 2,877 12-11-2022, 06:01 AM
  AASHTO T84: Standard Method of Test for Specific Gravity and Absorption of Fine A poolmand 0 3,069 12-11-2022, 05:55 AM
