Civil Engineering Association Civil Engineering Resource Civil Engineering Media Civil Engineering Videos Large-Scale Validation of Seismic Performance of Bridge Columns
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 278
Likes: 21,160 in 2,347 posts
Given Likes: 4240
11-03-2021, 07:59 AM (This post was last modified: 11-03-2021, 08:03 AM by Administrator. Edit Reason: N/A )
| Peresented By: Stephen Mahin; José Restrepo; Ian Buckle; Matthew Schoettler| Year: 2010| Format: mp4| Duration: 00:03:07| Size: 7.4 MB| Quality: 480
The seismic behavior of full-scale bridge columns designed based on current Caltrans practice is being investigated using the UCSD shake table as part of an extensive test program with E-Defense (Japan) and UC Berkeley in an effort to improve current bridge design and analysis practices.
This investigation will obtain, interpret and disseminate the first shake table results for full-scale bridge columns detailed consistent with current Caltrans design practice. Under the auspices of the Pacific Earthquake Engineering Research Center (PEER), the Federal Highway Administration (FHWA), the Department of Transportation of California (Caltrans) and the Network for Earthquake Engineering Simulation (NEES) program; and industry sponsorships from Skanska and the Concrete and Reinforcing Steel Institute (CRSI), this research project plans on testing a 1.2 m diameter bridge column with a mass of 250 ton placed atop, in order to mobilize inertial forces.
The column will be densely instrumented to obtain high quality data and tested under various earthquake ground motions, including motions of severe intensity demanding large inelastic response. Results of the test program will be compared with results of recent shake table testing of full-scale bridge columns performed in Japan at the E-Defense test facility and with shake table results from reduced-scale tests to be carry out at the University of California at Berkeley.
Combined with analytical simulations, the results will also provide a critically needed assessment of the adequacy of reduced-scale models and tests conducted at altered strain states. These will deliver the missing data required to increase the confidence in the current analysis methods and validate (or improve) present design practices. The testing will be carried out at the UCSD Large Outdoor Shake Table Testing Facility and is scheduled to run from July through September of 2010.
[/align]
[Image: 82322906297265820889.png]
[-] The following 11 users Like Administrator 's post:11 users Like Administrator 's post
  • jcbv, Dell_Brett, PinkPant, babakfeyzi, sodapas, civilphongvan, kowheng, zrilek, amindoxiti, RajaK, mowafi3m
  Performance-Based Seismic Design of Tall Buildings RyanRS 0 5,748 03-22-2016, 12:31 AM
Last Post: RyanRS
