Civil Engineering Association eBooks Geotechnical Engineering Soil Investigation and Mechanics Strength and Dilatancy of Sands and other Paper from M. D. Bolton
 gianniorlati
Senior Underground Works Engineer
Italy
User ID: 46169
Threads: 70
Likes: 1,673 in 128 posts
Given Likes: 429
09-17-2017, 07:42 AM (This post was last modified: 09-17-2017, 07:43 AM by gianniorlati. Edit Reason: N/A )
Geotechnical Design of Retaining Walls - Limit State Analysis in geotechnical Engineering - The Collapse of Diaphragm Walls Retaining Clay - The Strength and Dilatancy of Sands
  • Author(s): M. D. Bolton
  • Size: 3.36 MB
  • Quality: Scanner(OCR)
  • Abstract: Collection of M. D. Bolton's geotechnical research papers.
    It includes "The Strength and Dilatancy of Sands" paper (1986).
    .... "Extensive data of the strength and dilatancy of 17 sands in axisymmetric or plane strain at different densities and confining pressures are collated. The critical state angle
    of shearing resistance of soil which is shearing at constant
    volume is principally a function of mineralogy and can readily be determined experimentally within a margin of about 1 °, being roughly 33° for quartz and 40° for feldspar" ....
[-] The following 15 users Like gianniorlati's post:15 users Like gianniorlati's post
  • subin91, monter, blaze, civilfafa, freequo, PinkPant, Aviator, Ivan_1980, zrilek, nhim4mat2006, mgdario, Dell_Brett, Trishu999, cace-01, scorpion07
  Standard Penetration Test Procedures and Effects in Sands of Overburden, r gianniorlati 0 1,391 09-17-2017, 08:16 AM
Last Post: gianniorlati
