Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] paper - Near Surface Geophysics
[Request] paper - Near Surface Geophysics
 giguni
User ID: 20677
Threads: 121
Likes: 208 in 33 posts
Given Likes: 166
09-02-2015, 04:48 PM
Article/eBook: Combining surface waves and common methods for shallow geophysical survey
Author(s):Gaždová, R., Kolínský, P., Vilhelm, J. and Valenta, J.
Publish Date: 2014
Published By: Near Surface Geophysics, Vol. 12  pp. 19 - 32
Related Links:
 Mohammad6299
User ID: 42302
Threads: 261
Likes: 7,913 in 854 posts
Given Likes: 4212
10-17-2015, 09:06 PM
[Image: 53934057688421075903.jpg]
  • Author(s): Renata Gaždová, Petr Kolínský, Jan Vilhelm and Jan Valenta
  • Published By: Near Surface Geophysics
  • Published Year: 2015
  • DOI: 10.3997/1873-0604.2014039
  • Size: 2.45 MB
  • Quality: Original preprint
  • Related Link:
  • Abstract: Geophysical data were acquired during a survey of the Hluboká Fault in the Czech Republic, Central Europe. The recorded surface waves are studied in the frequency range 8–200 Hz. Phase velocity dispersion curves of Rayleigh and Love waves are determined from pairs of three-component seismograms with a 5 m receiver spacing by means of a frequency-time analysis along the profile. Rayleigh waves are analysed on the vertical (Z) and radial ® components and Love waves on the transversal (T) component. Dispersion curves from the vertical component are then inverted to 1-D S-wave velocity models using the isometric method. A set of 1-D S-wave velocity models representing a pseudo 2-D S-wave velocity distribution along the profile is obtained. This velocity distribution is compared with the results of other geophysical methods and also with direct observation from a shallow paleoseismic trenching. A combination of the S-wave velocities obtained from the surface wave analysis and P-wave velocities from refraction tomography is used to estimate the Poisson ratio distribution. It is shown that the resolution capabilities of surface waves are comparable in this case with electric resistivity tomography in near surface medium and with P-wave tomography in the depths exceeding approx. 15 metres.
[-] The following 4 users Like Mohammad6299's post:4 users Like Mohammad6299's post
  • ssobhan, zrilek, Dell_Brett, PinkPant
