Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 440.2: Guide for the Design and Construction of Externally Bonded FRP Systems
12-03-2010, 10:24 AM (This post was last modified: 03-20-2012, 07:36 PM by 3fan.)
ACI 440.2R-08 Guide for the Design and Construction of Externally Bonded FRP Systems for Strengthening Concrete Structures
Author: ACI Committee 440 | Size: 1.74 MB | Format: PDF | Publisher: ACI | Year: 2008 | pages: 80
[Image: 90839838151936442559.jpg]
and installation of FRP systems for externally strengthening concrete structures. Information on material properties, design, installation, quality control, and maintenance of FRP systems used as external reinforcement is presented. This information can be used to select an FRP system for increasing the strength and stiffness of reinforced concrete beams or the ductility of columns and other applications.
A significant body of research serves as the basis for this document. This research, conducted over the past 25 years, includes analytical studies, experimental work, and monitored field applications of FRP strengthening systems. Based on the available research, the design procedures outlined in this document are considered to be conservative. It is important to specifically point out the areas of the document that still require research.
The durability and long-term performance of FRP materials has been the subject of much research; however, this research remains ongoing. The design guidelines in this document do account for environmental degradation and long-term durability by suggesting reduction factors for various environments. Long-term fatigue and creep are also addressed by stress limitations indicated in this document.
These factors and limitations are considered conservative. As more research becomes available, however, these factors will
be modified, and the specific environmental conditions and loading conditions to which they should apply will be better defined. Additionally, the coupling effect of environmental conditions and loading conditions still requires further study.
Caution is advised in applications where the FRP system is subjected simultaneously to extreme environmental and stress conditions. The factors associated with the long-term durability of the FRP system may also affect the tensile modulus of elasticity of the material used for design.
Many issues regarding bond of the FRP system to the substrate remain the focus of a great deal of research. For both flexural and shear strengthening, there are many different varieties of debonding failure that can govern the strength of an FRP-strengthened member. While most of the debonding modes have been identified by researchers, more accurate methods of predicting debonding are still needed.
Throughout the design procedures, significant limitations on the strain level achieved in the FRP material (and thus, the stress level achieved) are imposed to conservatively account for debonding failure modes. Future development of these design procedures should include more thorough methods of predicting debonding.
The document gives guidance on proper detailing and installation of FRP systems to prevent many types of debonding failure modes. Steps related to the surface preparation and proper termination of the FRP system are vital in achieving the levels of strength predicted by the procedures in this document. Some research has been conducted on various methods of anchoring FRP strengthening systems (by mechanical or other means). It is important to recognize, however, that methods of anchoring these systems are highly problematic due to the brittle, anisotropic nature of composite materials. Any proposed method of anchorage
should be heavily scrutinized before field implementation.
The design equations given in this document are the result of research primarily conducted on moderately sized and proportioned members. Caution should be given to applications involving strengthening of very large members or strengthening in disturbed regions (D-regions) of structural members such as deep beams, corbels, and dapped beam ends. When warranted, specific limitations on the size of members and the state of stress are given in this document.
This document applies only to FRP strengthening systems used as additional tensile reinforcement. It is not recommended to use these systems as compressive reinforcement. While FRP materials can support compressive stresses, there are numerous issues surrounding the use of FRP for compression.
Microbuckling of fibers can occur if any resin voids are present in the laminate; laminates themselves can buckle if not properly adhered or anchored to the substrate, and highly unreliable compressive strengths result from misaligning fibers in the field. This document does not address the construction, quality control, and maintenance issues that would be involved with the use of the material for this purpose, nor does it address the design concerns surrounding such applications. The use of the types of FRP strengthening systems described in this document to resist compressive forces is strongly discouraged.
This document does not specifically address masonry (concrete masonry units, brick, or clay tile) construction, including masonry walls. Research completed to date, however, has shown that FRP systems can be used to strengthen masonry walls, and many of the guidelines contained in this document may be applicable (Triantafillou 1998b; Ehsani et al. 1997; Marshall et al. 1999).
Moderator note : Dead links deleted; only alive keeped; checked 20.03.2012 (3fan)
  • kowheng, pontiac, jcoronellr, vardan, kmmh76, usman, sodapas, jcbv, labofrock, paulocs, Struc-Con, oanm2000, blaze, malc, Dell_Brett, amir201, bigone, andersen3
03-20-2012, 04:55 PM
New working links:
  • seriousboy, 3fan, Dell_Brett, Jackass, eliseo.as, oanm2000, arceon, psa_1987, bigone
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,708 in 1,305 posts
Given Likes: 4621
11-01-2012, 11:10 AM
[-] The following 12 users Like lisine's post:12 users Like lisine's post
  • vvvv, fbx_rdnk, slowet, yamacdere, pedzaquino, Dell_Brett, draluka, bigone, kopauk, andersen3, subin91, avge
 PinkPant
Turkey
User ID: 25448
Threads: 66
Likes: 4,006 in 374 posts
Given Likes: 10354
06-16-2015, 01:40 PM
ACI 440.2R-08: Guide for the Design and Construction of Externally Bonded FRP Systems for Strengthening Concrete Structures
Size: 25.73 MB | Format: PDF | Quality: Unspecified | Publisher: American Concrete Institute (ACI) | Year: 2008 | pages: 76
PinkPant
[-] The following 17 users Like PinkPant's post:17 users Like PinkPant's post
  • tang1942, blaze, Dell_Brett, Jackass, cace-01, sinamaleki, amindoxiti, zrilek, f_slikken, oanm2000, paulocs, malc, Mohammad6299, kurt_dabs, Aviator, pedzaquino, spat
Likes: 8,200 in 1,338 posts
05-02-2023, 01:31 PM
ACI PRC-440.2-17: Guide for the Design and Construction of Externally Bonded FRP Systems for Strengthening Concrete Structures
Author(s)/Editor(s): ACI Committee 440 | Size: 13.85 MB| Format: PDF| Quality: Scanner| Year: 2017| pages: 112 | ISBN: 9781945487590
[Image: 80172986314071497249.png]
Fiber-reinforced polymer (FRP) systems for strengthening concrete structures are an alternative to traditional strengthening techniques such as steel plate bonding, section enlargement, and external post-tensioning. FRP strengthening systems use FRP composite materials as supplemental externally-bonded or near-surface-mounted reinforcement. FRP systems offer advantages over traditional strengthening techniques: they are lightweight, relatively easy to install, and noncorroding. Due to the characteristics of FRP materials as well as the behavior of members strengthened with FRP, specific guidance on the use of these systems is needed. This guide offers general information on the history and use of FRP strengthening systems; a description of the material properties of FRP; and recommendations on the engineering, construction, and inspection of FRP systems used to strengthen concrete structures. This guide is based on the knowledge gained from experimental research, analytical work, and field applications of FRP systems used to strengthen concrete structures.
Keywords: aramid fibers; bridges; buildings; carbon fibers; corrosion; cracking; development length; earthquake resistance; fiber-reinforced polymers; structural design.
  • babakfeyzi, Dell_Brett, milova, PinkPant
01-17-2024, 07:34 AM
ACI PRC-440.2-23: Design and Construction of Externally Bonded Fiber-Reinforced Polymer (FRP) Systems for Strengthening Concrete Structures
Author(s)/Editor(s): ACI Committee 440 | Size: 49.2 MB| Format: PDF| Year: 2023| pages: 109 | ISBN: 9781641952330
[Image: 19890847628918580994.jpg]
Fiber-reinforced polymer (FRP) systems for strengthening concrete structures are an alternative to traditional strengthening techniques such as steel plate bonding, section enlargement, and external post-tensioning. FRP strengthening systems use FRP composite materials as supplemental externally bonded or near-surface-mounted (NSM) reinforcement. FRP systems offer advantages over traditional strengthening techniques: they are lightweight, relatively easy to install, and noncorroding. Due to the characteristics of FRP systems as well as the behavior of members strengthened with FRP, specific guidance on the use of these systems is needed. This guide provides general information on the history and use of FRP strengthening systems; a description of the material properties of FRP; and recommendations on the engineering, construction, and inspection of FRP systems used to strengthen concrete structures. This guide is based on the knowledge gained from experimental research, analytical work, and field applications of FRP systems used to strengthen concrete structures.
aramid fibers; basalt fibers; bridges; buildings; carbon fibers; corrosion; cracking; development length; earthquake resistance; fiber-reinforced polymers; glass fibers; structural design.
  • babakfeyzi, subin91, PinkPant
  ACI 549.4: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Ce poolmand 0 1,475 01-23-2024, 12:10 PM
  ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels poolmand 0 1,693 01-17-2024, 07:27 AM
  ACI 440.7: Guide for Design & Construction of Externally Bonded FRP Systems for Stren ir_71 1 2,767 11-06-2023, 05:40 AM
  ACI 549.6: Guide to Design and Construction of Externally Bonded Fabric-Reinforce poolmand 1 1,734 05-09-2023, 12:39 PM
  ACI 440.1: Guide for the Design and Construction of Structural Concrete Reinforced wi poolmand 0 1,614 05-08-2023, 01:39 PM
  ACI 421.3: Guide to Design of Reinforced Two-Way Slab Systems poolmand 0 1,510 05-08-2023, 01:32 PM
  ACI 371: Guide for Analysis, Design, & Construction of Elevated Concrete & Composite lisine 3 3,684 05-08-2023, 12:20 PM
