Civil Engineering Association eBooks Structural Books Concrete Mechanical damage and crack growth in concrete
 amindoxiti
User ID: 86739
Threads: 203
Likes: 8,341 in 584 posts
Given Likes: 2618
09-25-2014, 12:04 PM
Author: Alberto Carpinteri | Size: 7 MB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 1986 | pages: 234 | ISBN: 9024732336 ISBN13: 9789024732333
[Image: 52115152586839011766.jpg]
Following Volumes III and IV that dealt with the fracture mechanics of concrete emphasizing both material testing and structural application in general, it was felt that specimen size and loading rate effects for concrete require further attention. The only criterion that has thus far successfully linearized the highly nonlinear crack growth data of concrete is the strain energy density theory. In particular, the crack growth resistance curves plotting the strain energy density factor versus crack growth known as the SR·curves are straight lines as specimen size and loading steps or rates are altered. This allows the extrapolation of data and provides a useful design methodology. This book is unique in that it is devoted specifically to the application of the strain energy density theory to civil engineering structural members made of concrete. Analyzed in detail is the strain softening behavior of concrete for a variety of different components including the influence of steel reinforcement. Permanent damage of the material is accounted for each increment of loading by invoking the mechanism of elastic unloading. This assumption is justified in concrete structures where the effective stiffness depends primarily on the crack growth rate and load history. Crack growth data are presented in terms of SR-curves with emphases placed on scaling specimen size which alone can change the mode of failure from plastic collapse to brittle fracture. Loading rate effects can also be scaled to control failure by yielding and fracture.
[-] The following 20 users Like amindoxiti's post:20 users Like amindoxiti's post
  • Saze808, oanm2000, gulilero, blaze, ssobhan, ykhackhack, vardan, Jackass, jfjdm, bridgeengineer, cace-01, Dell_Brett, malc, PinkPant, shadabg, mgdario, zrilek, hilander, subin91, Mohammad6299
  Damage and Cracking of Concrete Structures: From Theory to Practice poolmand 0 2,859 01-01-2023, 10:31 AM
  Mechanical Behavior of Concrete - JM Torrenti, G Pijaudier-Cabot, JM Reynouard Badis 5 3,206 07-20-2018, 04:00 AM
Last Post: axcel
  Crack Analysis in Structural Concrete: Theory and Applications noelda2 8 6,227 07-20-2018, 03:51 AM
Last Post: axcel
  ciria C660 - Early-Age Thermal Crack Control in Concrete AlmostThere 1 2,336 05-04-2015, 10:24 AM
Last Post: monter
  Alkali-Aggregate Reaction and Structural Damage to Concrete: Engineering Assessment, ir_71 3 2,270 08-04-2014, 06:33 AM
Last Post: ssobhan
  Mechanical Properties of Self-Compacting Concrete ir_71 1 1,635 05-29-2014, 05:44 PM
Last Post: cace-01
  Nanotechnology-Based System for Damage-Resistant Concrete Pavements mahyarov 0 1,300 10-29-2012, 06:22 AM
Last Post: mahyarov
